I had the same problem 2 times.
I have repair it myself both times (it is not an easy job).
Plastic grears on 2 motors are very sensitive.
They don't stick on side of the box (like all the others)
These 2 gears they are not sticked on the axle.
**** SO NEVER NEVER OIL THEM !!!!! ****
They will leave their possition more easy.
First failed the plastic gear that moves out the screen.
After a week it broke the other (that moves the screen up)
I suggest you to send unit to where you bought it
(I coudn't wait posts Athens to HongKong vice versa plus fix time).
Don't operate the unit, as you may do more damage.
If you decide to repair it yourself, glue the gear on other motor too.
For all the others:
DO NOT GREASE THE GEARS YOU SEE ON MOTORIZED LILLIPUT.
This way gears may last a little bit longer.
I'll have pics with broken gears uploaded when I'll go home.
LinkBack URL
About LinkBacks
.... anyone found a supplier of the cogs?... i can't see lilliput having them custom made
