Results 1 to 10 of 10
Thread: lilliput out of range
    Jan 2007
    ok my lilliput was working sweet in 800x600 then i pressed the auto adjusting button and hey presto 800x600 wont work
    is there any way of restoring the lilliput to default any way through codes or anything like that?
    its deffo somthing stored on the monitor somewhere
    is there any way or sorting this problem out i have contact the people who i brought it off and they have no answer and there lilliputuk
    a code to reset the lilliput will sort it im sure as it used to work
    what other options are there to sorting this option?
    I have tried changing the refresh mhz but that didnt cure it either
    im thinking of trying MCE2005 in 1024 mode or just change the ini file in road runner
    Jan 2007
    forgot to add the monitor is 629GL-70NP
    Constant Bitrate ephyouckay's Avatar
    Oct 2006
    Lilliput and SVGA and Laptop
    im having the same problem... i figured out its got nothing to do with my cable because it worked a few times but still not very consistent.
    let me know if you fixed it.
    Constant Bitrate rigg419's Avatar
    Apr 2006
    Behind the Orange Curtain
    see THIS thread
    Feb 2006
    Vancouver, BC
    it's your refresh rate. Change it on your comp and it'll be all good. Had the same problem.
    Oct 2006
    thanks rig.. i need to try that 1024x768@60hz setting.. i was just messing with 800x600 before and come to think of it when i plugged in my other laptops into the lilli it was fine but thats because those were in 1024x768 res. ill have to try this hope its the solution for me.
    Jan 2007
    right sorted mine out by starting at the highest freqency on 800x600 keep switching between 2 monitors and just dropping it tilll i got a picture job done
    cheers guys
    Oct 2006
    got mine working too
    Apr 2006
    glad to see we're all getting this problem fixed one way or another
    Apr 2007
    please god fix mine. It happened to me, 800x600, auto-adjust freaked out, now I can't get 800x600 no matter what (tried refresh rates of 60, 75, 85, and 100).
    HELP!!!!!!!!!!
    Why did they put the autoadjust right next to the f'in brightness button anyway!?!?
  1. Replies: 7
    Last Post: 01-24-2007, 10:31 AM
  2. Lilliput and SVGA and Laptop
    By ephyouckay in forum LCD/Display
    Last Post: 01-16-2007, 10:51 PM
  3. Flickering in Lilliput
    By phatchink in forum LCD/Display
    Last Post: 07-30-2005, 05:34 AM
  4. Xenarc Touch Panel on Lilliput Controller
    By badandy4you in forum LCD/Display
    Last Post: 06-04-2004, 01:54 PM
  5. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
