Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Got my Xenarc in today!!!
  1. #11
    Jul 2002
    Thanks mikeinsanmarcos I was just about to say that
  2. #12
    May 2002
    YAY!! Talked to the guy at SpySupply007 (very nice guy) and he said they've NEVER had an issue with the Xenarc monitors, nothing like this. So, maybe it was a weak screen.
    SHOULD it work plugging it directly inline, or will it fry it everytime?
    He is over-nighting me one, and i'll just send mine back (with the good cable, not my spliced one).
    So, if anyone is interested in a Xenarc, I recommend SpySupply!
    Thanks for the help guys, I can now sleep at night.
    Clayton
  3. #13
    Jun 2001
    Boise, ID (USA)
    When you say inline, it sounds like you are putting it in series with your power supply! Parallel would be the only way to wire it up... I cant think of any reason you wouldnt want to power it off the carputer power supply unless it is not powerfull enough.. You might even be experiencing grounding issues if the power supply is not grounded to your chassis!
    Mike
  4. #14
    May 2002
    I wired it and my power inverter from my AMP power wire and then to a ground under my middle console. Inverter works fine.
    Thats what I call "inline" Probably wrong term.
  5. #15
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Inline would be if you had:
    + > amp/psu/etc > screen > -
    in which the amp/psu/etc would ground through the screen. I'd still be a bit aprehensive putting it dirrectly on the battery if the req. are 8-14vdc, as I've seen my own car put out over 14vdc.
    -Nick
    _____________________________
    www.mp3vw.com
  6. #16
    May 2002
    thanks for the explanation! i get it now.
    I bought a power inverter with two pluugs last night, so thats what i'll be using. Not gonna try that again.
    Thanks guys!
  7. #17
    Aug 1999
    Upper Marlboro, MD 20772
    yep...i think u fried it...to be safe, get the power from ur psu.
    abcd-1
  8. #18
    Jul 2002
    Cng1, when you spliced the wires, did you check the correct polarity? (Because it's hard to tell which one you need to connect to ground and which one you need to connect to +12V) Could the screen got fried due to wrong polarity?
  9. #19
    Maximum Bitrate Skippman's Avatar
    Mar 2002
    St. Louis, MO
    I told him to check that. I bet that's acutally what happend. Reverse polarity on an LCD is bad Mojo as far as I've heard.
  10. #20
    May 2002
    Whichever wire had the tiny white text on it, I assumed was the power. Is this correct?
    I'm not splicing the wires anymore. Just gonna do the inverter thing. No more chances!!
    Thanks for all of your replies.
