worked great. Thanks for making this available
Ok everyone, i've been messing with the screen for a good part of the day. While most of the info on here on how to switch the auto on is correct, there are a few steps that are left out here and there that are very important. I'm going to try to on how to do this "Step-By-Step"
1. Power on your computer and EBY701 so it has a VGA signal
2. Wait until the blue menu lights turn off (Except the Power obviously)
3. Press "588998" on your remote. No need to type super slow or pause between numbers, just make sure you press everything
3. A language menu will come up.. Let that menu sit there until the blue menu lights turn off again
4. Press the MENU button on the screen. This will bring you to the factory menu
5. Press the ">" button on the screen until "POWER MODE" is highlighted
6. Press "Vol UP" button until POWER MODE is "1"
7. Press "MENU" on the screen
8. Press "MENU" on the screen again to exit
9. Unplug the power. Plug it back in
Hope this works for everyone!
I tried and I tried for hours yesterday, every method proposed on this forum to get my EBY701 to auto-on but I NEVER get any of these "special menus" that are talked about. Anyone still having problems with there's despite attempting all the different suggestions on this forum?
one suggestion posted from someone before stated that you should try removing the battery from the remote and putting it back in. Try that and let us know.
i tried that a few times. didn't work :-/ I'm pretty sure i've tried everything suggested on this forum. I was just trying to find out if anyone else had tried everything on the forum and still not gotten it to work.
not sure about this display, but on the transflective display which I got last week I had to 1) do the battery removal, and 2) the setting for the power mode was 2 not 1. HTH.
Worked fine fo my eby701........
Cheers
BJ
Dont worry AznArkitekt, I have the exact same problem. I cant get mine to go into the programming mode to save my life. I even left the batteries out of the remote for a week to see what would happen, still didnt work. Really ****ing me off =(
confirmed it works as bobbykinos says, u have to follow Exactly, and by exactly, i mean EXACTLY.
no point leaving the battries off or whatever, becos u only need that to press 588998, the rest is on the screen.
