Results 1 to 9 of 9
Thread: Touch Screen Touch Reversed
    Nov 2005
    I have an issue with my touch screen operating in reverse side of the screen as well as being inverted anyone else ever have this problem? could it be a driver problem?
    Mar 2006
    Colorado, but Canadian!
    you have to calibrate it
    1.9in x 2.9in -- 47mm x 73mm
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Quote Originally Posted by 2k1Toaster View Post
    2nd that. My screen does exactly as you say, until it is calibrated. You do that using the touch screen utility provided on the cd that came with your screen.
    I installed my carpc into my pet Kangaroo, mate.
    Low Bitrate BLAXKINNED's Avatar
    Jan 2007
    OakLaHoeMah
    I had the same problem while testing mine today. You've got to make sure you install the right driver for your OS. I had to uninstall mine, and then re-install, and it worked.
    Nov 2005
    problem is the cd that was sent with my screen for some reason is BLANK!!
    Can i use any other caliberation software??
    Mar 2006
    google for "touchkit drivers" and download the ones you need. I use them, and they are ususally what is packaged with them. And a blank CD is common, expecially if it is one of those mini-cd's.
    Mar 2006
    Nov 2005
    thanks screen is workig perfect now!! WOOHOO thanks alot
    Mar 2006
    no problem
  1. In-dash touch screen vs touch screen overlay
    By vxcarpc in forum LCD/Display
    Last Post: 09-22-2008, 11:52 PM
  2. Lilliput 8" touch screen backwards - FC4
    By DJBigShow in forum Linux
    Last Post: 08-04-2006, 03:43 PM
  3. Lilliput touch screen Help..please
    By avn128 in forum LCD/Display
    Last Post: 08-03-2006, 05:20 PM
  4. Need touch screen advice
    By sciff5 in forum LCD/Display
    Last Post: 05-29-2005, 10:58 PM
  5. task switching? touch screen only
    By chuckctv in forum Software & Software Development
    Last Post: 09-04-2004, 10:50 PM
