Results 1 to 10 of 10
Thread: Powering your lilliput
    Constant Bitrate stangg172006's Avatar
    Jan 2007
    Morton Grove, IL (Northside Chicago)
    Hey guys and girls. Im looking into getting a carputer in my MKV Rabbit and am just doing some research/gathering materials. In doing my research for a screen, ive decided on a 7" Lilliput screen. Im looking for a totally clean install and will be using a bezel to custom fabricate the screen into the dash and i want only the screen being visible up front. Since the screen comes with a 12v cigarette lighter plug, how did you guys end up powering the unit? And just so that im clear on this, you ran the vga from your computer to screen, a usb from the screen to the computer and finally power to some unknown place. Man this carputer business sure is a lot harder then i expected. Thanks in advance for responses!
    Mar 2006
    Colorado, but Canadian!
    well you can either run a seperate line to the battery for it, or use the power supplies 12v rail to power it.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2007
    Quote Originally Posted by 2k1Toaster View Post
    which calls for cutting the original cigarette lighter plug and connecting it a separate wire tot he battery? how would i regulate the power? or does it even matter since its a 12v source and the screen runs off of 12vs? Thanks for the response!
    Mar 2006
    yes if you cut the cigarette lighter plug from the lilliput then it will take whatever the car can dish out. Usually there is an egg on there. Meaning a bulge in the cig lighter to the screen. If not then look on the back of the monitor and see if it says 11-14v in or 12v in. If it has a range, then the regulator is inside. If it is a fixed voltage then the regulator is outside.
    Jan 2007
    so i would have to cut the wire after the bulge, assuming its not a fixed voltage.
    this is the screen im looking at by the way... http://cgi.ebay.com/Lilliput-7-Touch...em300075748734
    Mar 2006
    if there is a buldge, then when hardwiring your screen, make sure that buldge is included.
    Jan 2007
    thanks for the help 2k1Toaster!
    Nov 2006
    stangg.. where did you end up wiring the Lilliput ?? i am thinking of tapping to the 12v from factory headunit cables, but not sure if this is a good idea ??
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    Quote Originally Posted by CoupeE46 View Post
    headunit input voltage isn't strictly 12v! i would bad idea.
    Nov 2006
    ok after putting together the cpu today. i will be running offf the molex connectors from the psu..
  1. Powering Lilliput.
    By bimmeracer in forum General Hardware Discussion
    Last Post: 01-03-2006, 04:17 AM
  2. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 06:26 PM
  3. powering lilliput lcd from opus psu .
    By robutek in forum Power Supplies
    Last Post: 06-13-2004, 03:51 PM
  4. powering up a lilliput thru a regulator
    By masch in forum LCD/Display
    Last Post: 01-25-2004, 02:57 AM
  5. Powering Lilliput
    By telstargb in forum Power Supplies
    Last Post: 01-20-2004, 08:01 AM
