Results 1 to 3 of 3
Thread: Lilliput GL701 Flipout Problems (Video of it)
    Jan 2007
    Before I installed this unit in my car, I tested it off of an ATX power supply and it worked fine. I then installed it into the car and hooked it up to an M1-ATX PSU and I have some strange problems. The screen comes on after I turn the key, but it flickers between Video 2 non stop. It will only stop if I press and hold the mute button or press some random combination. It then goes onto say "No Input Signal" and then turns off. I'm thinking it's a power issue. Eventually, however, after mashing enough buttons, I was able to get it to switch to PC input, but the TS wasn't working.
    http://www.youtube.com/watch?v=uULsCEw3NaM
    _
    Mar 2004
    Little Elm, Texas
    what have you done to trouble shoot the issue?
    Have you checked all your connections? Have you tried it off of the ATX again?
    If you took it apart, did you check everything once you put it back together again?
    Jan Bennett
    Jan 2007
    Quote Originally Posted by RedGTiVR6 View Post
    I'm going to check the connections once more, but it's a pain to get the dash out and it's snowing so I haven't got the chance to do too much testing. I've never taken apart the unit either. Another thing that's weird is that the screen has horrible color, like a red tint over the whole image. I'm guessing that's because I have a cord loose.
  1. mpc problems for video & dvd
    By kuo in forum Road Runner
    Last Post: 09-28-2005, 08:18 AM
  2. Video 2? on lilliput
    By Sin in forum LCD/Display
    Last Post: 09-13-2005, 03:37 PM
  3. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
  4. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
  5. Lilliput problems (yet some more)
    By samc in forum LCD/Display
    Last Post: 05-06-2004, 10:51 AM
