Dont think you will be able to do it without going through other hardware first. http://www.theavguide.co.uk/view_page.php?page=18 is a link to the pinout of VGA
Hi Everyone,
Can anyone help me figure this out. I have a 13-pin RGB connector on my monitor is it possible to use this monitor with a VGA connector to hook up the computer.
Here are the pin-outs.
Thanks for all your help!
-Devin
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
hmmm any ideas on what I would require as the other hardware?
VGA to RGB converter, there are loads of options but your probably cheaper buying a VGA screen plus you will get much better quality from it.
Can't use a VGA screen as this is the unit I am using its all built in.
http://www.thexenonstore.com/mazda3_screen.php
-Devin
devin98,
I found a solution, i believe. The connector is a Atari ST (old school i know) video port. I found an adapter on a british online store that has an adapter from the traditional 13-pin atari connector (same pins as the navi port on ur monitor) to the vga connector.
Here's the direct link
http://www.mazda3forums.com/index.ph...788#msg1260788
Search this site for PSOne mod.
Not a direct solution, but it give you some guidance on your project.
Maybe this converter Nice VGA-to-CGA converter - for in-car LCD's will make your life easier too.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
