7" lilliput eby701 and displayconfigx problem
i just installed displayconfigx on my intel mac mini. i attempted to adjust some settings but closed the program before applying the changes, this i am sure of. now when my lilliput is connected to the mac mini it says "signal out of range" yet when connected to my pc its fine. an alternate display on the mac mini works fine too.
How can i erase the "cache" stored from the lilliput on the mac so it will use the default settings when connected? thanks
bump for suggestions. this is really strange, i have searched these forums for an answer but nothing seems to work. I have tried every possible thing to get the screen to work on the mac again to no avail. The mac output works fine on other screens except the touch screen. and the touch screen works fin on other computers except the mac.
bump.....
i think its a setting in osx that stores and loads the wrong display config when the lilli is attached. there is a commpand that displayconfigx gives you: hold apple key+s during boot and enter
mount -uw /
rm /System/Library/Displays/Overrides/DisplayVendorID-2283/DisplayProductID-178c
however the display vendor id and product id are of the current screen attached, not the lilli. any suggestions on what to do from here?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
