Originally Posted by
DarquePervert
I do believe that you are talking about WATTAGE output of the inverter, not VOLTAGE.
If it put out 1500 (or 700) volts, it would destroy anything out plug into it. It should put out 110volts (US spec) or 220volts (Europe & elsewhere spec).
Amps are what are dangerous, not volts or watts. You could have 10,000 volts, but less than one amp and you would survive just fine, despite burns and twitching muscles.
However, one volt at 50A could kill you.
The notion that a shock felt in your fingers means it's not travelling throughout your body is also false. The nerve endings are in your fingers, that's why you feel it there.
