Results 1 to 8 of 8
Thread: Refreshing problem?
    Jan 2007
    Refreshing problem?
    Hey.
    I have Xenarc 700TSV in my car and graphics controlled on board (Intel D845GBV). When I turn the pc on refresh rate is really visible. I thought that it might be an interference due to power cable running next to video cable so I hooked up my laptop to check it out. Xenarc works just great with my laptop, however it doesn't with my carpc. I have the newest drivers installed and I still see the problem.
    Anyone knows how to fix it?
    Thanks in advance
    Elsewhere
    That's a function of the monitor, not the PC.
    How about the Wiki?
    Jan 2007
    Why is it working fine with the laptop though?
    Aug 2005
    Pennsylvania
    It could actually be noise from your power source. Where is it powered from?
    Jan 2007
    Its powered from the ignition on cable. Same as the radio.
    PC is powered same way, and power cable runs next to video cable. Although when I hooked up my laptop in the same place where my pc is placed (with the pc on in order to create similar power noise)it was working just fine.
    Feb 2006
    I had noise like this until I drove the monitor off my computers power supply. Try that, it might solve your problem.
    Variable Bitrate rubicon's Avatar
    Feb 2005
    $240 worth of puddin'
    You're probably going to want a cleaner source of power than that.
    Aug 2005
    Pennsylvania
    Quote Originally Posted by EricE View Post
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
