I"m using that board with XP and i'm pretty sure it's not xp or the driver.. Many tv outs sense to see if a device is connected by checking the resistance.. If you wire a 75ohm resister on there it should fix it. I'm not really sure where you are supposed to do it but if you search the forums I'm sure you'll find it... It's been brought up a few times.
If that doesn't solve it.. I'm not sure what will... Does the Legacy screen work with any other input?
LinkBack URL
About LinkBacks
