Results 1 to 10 of 15
Thread: M2-ATX J9 - External Power Switch - Busted?
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I have my M2-ATX all wired up and everything is working except the J9 power switch.
    I have J9 connected with a two wire plug to a simple push button. With the M2 getting power (LED is lit) I try and push the button and the PC doesn't turn on..
    Thinking it may be the switch I removed the wires from the switch and just touched them together, still nothing.
    I then tried grounding the pins together on the M2 itself, still nothing.
    Is that something that can happen? J8 powers on the motherboard fine..
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Try this
    ~Jimmy
    Oct 2003
    Poland, OH
    No, it's not the same. I know you have to first give the M2 an IGN on signal before you can use the J9 power button.
    That's what I meant by saying the M2 had power with the LED. The jumper you have with the 2 hours hard off means that the M2 will stay powered for 2 hours. In those two hours if you PC is off I should be able to use the J9 power button to power my PC on.
    Thanks for the reply.
    Variable Bitrate Nerd2's Avatar
    Dec 2006
    Bristol/Cambridge, England
    J8 and J9 are hard wired together.
    What do you mean J8 powers the motherboard fine?
    You should have (Mobo power header) -> J8, then shorting J9 will start the motherboard.
    Oct 2003
    Poland, OH
    J8 is connected directly to the motherboard.
    J9 is connected to a momentary push button switch.
    When I turn my truck on the IGN signal is sent and the motherboard powers up and works fine.
    When I turn my truck off, the motherboard shuts down correctly. I should now have 2 hours to be able to power up the motherboard by using the J9 switch.
    When I press the J9 switch nothing happens.
    Does that make sense?
    Dec 2006
    Yes it makes sense.
    Option 1) - connection between J8 and J9 is broken. Easy to test, try to power on mobo by shorting pins on mobo, try swaping mobo power from j8 to j9, check continuity between j8 and j9. Very unlikely.
    Option 2) - the mobo may only be powering on due to the m2 atx kicking in, not from the IGN signal (is your BIOS set up to resume on power on?). Double check cable runs to right pins on mobo
    Oct 2003
    Poland, OH
    Quote Originally Posted by Nerd2 View Post
    The M2 doesn't come on until it gets the IGN signal which in turn sends the signal to J8/J9 to power on the motherboard, right?
    Dec 2006
    Quote Originally Posted by tbird2340 View Post
    Yep - what may be happening is the M2 is sending the signal to J8/J9 but that is getting ignored by the motherboard for some reason (explaining the failure of J9 to work). The motherboard may STILL turn on, just from noticing that power has arrived. Some BIOS's do this. Think of some PCs turning on automatically just from having the power cord plugged in.
    There are loads of simple tests you can do to rule this out though.
    Oct 2003
    Poland, OH
    The first being simply take the cable going from the motherboard header which I *assume* is working and move it to J9 instead of J8?
    Dec 2006
    Yes.
    Second, remove it completely.
  1. Need wiring help for 2005 Grand Prix.
    By derekmac in forum Car Audio
    Last Post: 09-21-2007, 10:42 PM
  2. Factory A/C switch + relay= inverter power switch
    By CTcarPC in forum Power Supplies
    Last Post: 02-10-2007, 04:02 PM
  3. NIB M2-ATX DC-DC ATX auto car PC power supply mini ITX EPIA
    By ichiban in forum Classified Archive
    Last Post: 07-21-2006, 01:00 PM
  4. OPUS peoblem SOLVED!! read me
    By revlis240 in forum Power Supplies
    Last Post: 10-23-2005, 09:49 PM
  5. PS2 used as case and working PS2 reset/eject switch as power and reset
    By Silentbob343 in forum Hardware Development
    Last Post: 09-07-2005, 11:09 AM
