Try checking that you have a good 12V power source. If running a mains power supply, ensure it has sufficient Amps to run your pc. If in the car, make sure that the wires you have connected are heavy enough.
Hello, first post here!
I have recently purchased a M2-ATX to use in my car-pc, however I seem to be having problems with the power switch to the motherboard.
Firstly, I've tried the motherboard by shorting the pins on the board and it boots fine, the problem only exists when connecting J8 (or J9 for that matter) to the power switch pins on the board.
The board boots initially, then runs for a few seconds before powering down. The switch itself, after probing with my multimeter, appears to be closed permanently so it's as if the power switch is pressed all the time which would explain why the board boots up and then shuts down.
If I connect the cable to the board momentarily and then remove it the board powers up completely and runs, until I reconnect the cable where after a few moments it shuts down.
I've already had a search of the forum and I can't seem to find a solution, so I'm wondering if the M2-ATX unit itself is broken! Any help or advice you can offer is much appreciated!
I'm having that exact same problem today. My MB reacts differently - it does nothing at all if I have the power button connected to J8 or J9 on the M2. Those pins are shorted all the time. If I unplug J8 and J9 and manually trigger the MB, the whole thing runs just fine. Therefore: The MB is OK, the M2's output is OK. The problem is the switch logic on the M2. Anyone have any advice besides an RMA?
There's a discussion of this here (but no solution, the consensus seems the M2-ATX is fried):
M2- ATX issues ( searched!)
Also here, with no solution or conclusion:
M2-atx mystery
Also narrowed down to the same problem (J8 resistance not changing):
M2-ATX problem...again
Elantra GT 1.2GHz Duron, RoadRunner & LSX Void 3.2. Status: Stable...
allypally- I'm currently powering the M2-ATX from a conventional PSU, which provided plenty of power for the system to run initially so I'd assume that's not the weak link.
cobase - You're right, your problem sounds identical. From reading the threads you linked it seems I'll just have to RMA the board! What I don't understand is why it just decided to stop working properly for no apparent reason, and I can only hope that the new one doesn't do the same.
Agreed, I guess I will too. Mine failed while I was driving, so it seems pretty spontaneous to me. Just...poof. I got replies both from mini-box.com and Logic Supply.com (where I bought it):
Logic Supply: " When you're bench testing the M2-ATX you'll want to make sure that there are
no jumpers on the J10 panel. With the M2 hooked up correctly you should have
the J8 connected to the power switch pins on your mainboard. Be sure that
you've got the polarity correct for both. If one is Pos-Pos Neg-Neg and the
other end is Pos-Neg Neg-Pos it will not work.
mini-box: "We use a 1 bit BUS switch to simulate ON/OFF, if you hook up J9 in the wrong
place you can damage it and probably 'short'... I suggest an RMA..."
So I think that settles it for me - I thought the J8/J9 polarity was irrelevant so I can't say which way I plugged it in. They should specify that in the manual.
I just got my M2-ATX back from LogicSupply. They fixed it under warranty with no comment about what went wrong. Not slow either - just under two weeks. I haven't tested it yet though.
I had my replacement last Thursday - works perfectly now and I've had no problems so far. I held my breath as I started it the first time, thankfully it worked. Fingers crossed it stays that way!
LinITX are "investigating" the problem with the one I RMA'd, but so far I've not heard anything more from them.
Turn the switch connector round. Sounds stupid as it is just a momentry close but it works. Its something to do with how the M2 simulates a button press
usually found at digital-car
Thanks Baj, I heard from others that this had worked for them, unfortunately it wasn't the case for me! My problem was that the switch logic was continually high, as if the power switch was constantly on; not a problem that could be solved by reversing the connector.
