Personally I wouldn't use the chassis grounds, use the grounds on the molex instead.
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
I agree ^^^ Use the Molex's grounds. The M2 should be connected to chassis ground and all ground from each component should connect to there through your splitter.
Make sure to get the correct gauge wire for the M2's connections to 12V and GND.
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 90%
Installation/Fab/Assembly (Revised v2):
[----------] 90%
is there a reason to use the molex grounds instead of chassis ground? I was going to use chassis ground so I would have to run one less wire to the component I'm powering. Not a big deal. Is the molex ground somehow a more stable ground point than chassis?
id do some seperate power supply for at least the external drive and lillyput or teh lillyput and usb hub, or usb hub and external, id remove two of the components from the M2
If I did my power consumption calculations correctly, I should have enough power to run all of my components through the M2. But looking at my wiring diagram again, I realized that the HD Radio doesn't need regulated 12V, so I can just plug that right into my battery. Also, the only USB devices I'll be using are a GPS receiver, wireless keyboard, and USB for the touchscreen, so I guess I won't really need a hub anyway.
So crossing out the HD Radio and USB hub, I shouldn't need another power supply for the Lilliput and DVD drive, right?
This is slightly off topic...
But thank you so much for posting this! One of the things that was confusing the hell out of me was how to power the monitor and the computer. I figured there should be some easy solution involving the PSU but was concerned about the whole thing being overloaded.
Thanks again!
I hope your not planning on using a PCI sound card with that M2!
