Results 1 to 10 of 13
Thread: M2-ATX with Intel Atom Motherboard Issues
    Jun 2006
    SPECS:
    M2-ATX Power Supply, Intel D945GCLF (Atom) motherboard, 1GB RAM, USB keyboard/mouse connected only.
    I'm pretty sure I have a defective M2-ATX power supply but I thought I'd explain my issue here and see what everyone thinks. Prior to the Intel Atom motherboard I had an EPIA M10000 and everything worked great.
    Basically the main problem is whenever I turn the ignition off the PC restarts regardless of what mode it is in (dumb psu or jumpered) instead of powering down.
    Example: When I have the M2-ATX in jumpered mode 5s/45s and turn the ignition off the PC will reboot and then power off 45 seconds later. (does that make sense)
    This is a problem because I usually have the PC go into hibernate after pressing the power button to speed up boot times. However, when the M2-ATX sends the signal to the motherboard to power off (hibernate) it acts more like a reset button instead.
    Even if the J8 switch wire is disconnected from the motherboard it still restarts the PC when I turn the ignition off.
    If I hook up the motherboard to a standard power supply it can be turned on and off with the power switch just fine. I also made sure the option in the BIOS to power on after power failure was turned off.
    Any other things I can try or do I need a new power supply?
    Mar 2006
    Colorado, but Canadian!
    Sounds like a simple wiring issue. Can you verify with a multimeter your cables are correct? Might have accidentally switched them when you reinstalled it.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2006
    Quote Originally Posted by 2k1Toaster View Post
    Which cables are you referring to? If any cables are wired incorrectly the thing shouldnt turn on in the first place, right? The only problem is when shutting down, other than that everything turns on and works great.
    Jan 2007
    Toronto
    check which pins you have the power and reset wire attached to.
    {|---------} 10% Done A Long Long Long Way To Go.
    Jun 2006
    Quote Originally Posted by jettamaster View Post
    Yeah, that was the first thing I checked I verified with the motherboard manual that I had the wire connected to the correct pins. Anyways, if I had the J8 switch on the M2 connected to the reset pins on the motherboard then it wouldn't start up.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by jeremy480 View Post
    It would if the bios was set to power up when power is received.
    Jun 2006
    Quote Originally Posted by Rob Withey View Post
    Well, there is no option in the BIOS to power up when power is received. The only thing is to power up when power is lost, but as I mentioned above that setting is disabled. Either way, I verified the wiring is still correct.
    I appreciate the feedback but I think I will try a new power supply.
    Jun 2006
    Replaced the power supply and now everything works great!
    Jun 2008
    Rancho Cucamonga, California
    I really dont know if I am having the same prob as you jeremy, but I also have the new atom board, and I also have the M2-ATX and what mine seems to be doing is when I start the car, it seems to start up and even displays that its resuming windows in the monitor, and then it looses signal to the monitor but is still powered on. Even the bluetooth adaptor is flashing which means its still in windows, but no picture is displayed. If I turn the car off, it seems to finally get a signal to the monitor and finishes booting into windows. If I turn the car back on it seems to hibernate again, and I basicly have to keep messing with the ignition to get it into windows correctly. I have checked all my wiring and its good, and seems to be getting enough current for the power supply. I have it set to 5s/2hr. which it said was the recomended setting for the PS. Please let me know if this seems like the same problem. All my equipment is new and I just set it all up.
    May 2006
    Hi Jeremy Actually I'm having the same exact problem that you were experiencing. Did you ever find out what the problem was? I turn off the ign and the the computer just turns off immediately and then restarts again and then a little later it will just power off. Which vendor did you buy it from?
    Car: 2007 Honda Accord Sedan SE
    My Worklog
    http://www.mp3car.com/vbulletin/work...da-accord.html
  1. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 05:36 PM
  2. FAQ REQUEST: CPU Ratings
    By dontpntpool in forum General Hardware Discussion
    Last Post: 03-18-2007, 04:39 PM
  3. Normal ATX motherboard or mini PC?
    By Spongebob in forum General Hardware Discussion
    Last Post: 08-27-2002, 08:35 PM
  4. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 03:22 PM
  5. Noise fix for ATX motherboard
    By smr61 in forum General Hardware Discussion
    Last Post: 03-04-2001, 10:34 PM
