Results 1 to 10 of 10
Thread: Fuse question for my M2
    Aug 2008
    SouthernOK
    I have an M2 power supply. I need to know what size of in-line fuse to use at the battery. All I had on hand at the initial hookup time was a 3A and a 15A, so I used the 3A which did ok with just the computer and hd hooked up. But tonight when I added my 10" touchscreen the fuse blew.
    The M2 has a 15A fuse on board.
    2004 F150 STX Heritage:
    Parts:
    ASUS E35M1-I Fusion AMD 1.6GHz DC ~$114
    Patriot 32GB SSD ~$80
    Kingston 4GB ~$25
    1/2" MDF - ~$15
    10" Samsung touch panel - ~270
    M2 Power Supply $85
    GPS Receiver ~ $36
    iGuidance ~100
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    the M2 can draw up to 15A, so the fuse on your power wire should be 15A (or more). the actual fuse [rating] you use should be no higher than the maximum ampacity of the wire gauge you use to power and ground your M2.
    Aug 2008
    SouthernOK
    Well I used 16 gauge wire cause that is what the leads that came with the power supply was.
    Parts:
    Kingston 4GB ~$25
    1/2" MDF - ~$15
    M2 Power Supply $85
    GPS Receiver ~ $36
    iGuidance ~100
    Elsewhere
    I highly suggest 12 gauge or thicker to prevent overloading the wires, especially on a run of more than a couple feet.
    For most PC installations, 10 gauge is pretty bulletproof and not difficult to work with.
    How about the Wiki?
    May 2007
    Boston
    as Darque said, it would be best to use thicker wire (10-12awg).
    however.. if you insist on keeping the 16awg wire that you already ran, then the highest fuse [rating] you should use is 7.5A
    Aug 2008
    SouthernOK
    Thanks everyone. I re-ran 10gauge over the weekend with a 15amp fuse.
    16gauge is fine for the ignition wire right?
    Parts:
    Kingston 4GB ~$25
    1/2" MDF - ~$15
    M2 Power Supply $85
    GPS Receiver ~ $36
    iGuidance ~100
    May 2007
    Boston
    Quote Originally Posted by 04f150stx View Post
    yes
    Low Bitrate Belo's Avatar
    Jan 2010
    Buffalo, NY
    this is an older thread, and I'm about to do the same. Just wanted to make sure a 15amp fuse is still recommend for the m2
    09 Pontiac G8GT [decently modded]
    former carputer owner, given up for iphone
    Dec 2008
    a 15a fuse is whats on the m2 itself, so another 15a fuse located at the source of power (usually battery) is a good idea.
    Aug 2008
    SouthernOK
    I'm still running it with the same setup. No problems 1 year later.
    Parts:
    Kingston 4GB ~$25
    1/2" MDF - ~$15
    M2 Power Supply $85
    GPS Receiver ~ $36
    iGuidance ~100
  1. A general car wiring question
    By lloydi in forum General Hardware Discussion
    Last Post: 09-12-2007, 01:30 PM
  2. P/S M2 question
    By Focal in forum Newbie
    Last Post: 07-23-2007, 10:43 PM
  3. Fuse popping, wire heating up!
    By gumbi4u in forum Power Supplies
    Last Post: 06-29-2006, 11:01 AM
  4. Inline Fuse Holder Question
    By dbzeag in forum Car Audio
    Last Post: 01-31-2006, 04:38 PM
  5. Car Battery, Fuse and Multimeter Question
    By timwiththebo in forum Newbie
    Last Post: 12-19-2004, 09:26 PM
