Results 1 to 10 of 12
Thread: Possible to shorten 5 second delay on M2-ATX?
    Jun 2008
    Seattle, WA
    I'd like the computer to be on as fast as possible after turning the key. Any way to shorten, or get rid of, the 5 second power on delay?
    Thanks!
    -- Kevin
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    You have to reprogram the PIC chip on the M2 to change the delay value. But I have no idea how, maybe someone more knowledgeable can chip in.
    Jul 2006
    seattle
    Yes.
    nobb is correct, you need a pic programmer.
    source code of m1-atx:
    http://www.epiacenter.com/modules.ph...rticle&sid=529
    I believe the source code for m1-atx and m2-atx are identical.
    reference thread:
    M1-ATX microcontroller source
    dsatx in voompc 2 case <HERE>
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    So does anyone know anything about the actual chip itself? What kind of programmer do you use? If it is a common chip and programmer, then maybe I can find an EE prof at my university who might let me use one of these...
    Jul 2006
    seattle
    looks like just a pic12/16. any pic programmer would do.
    pickit2, picstart plus, etc.
    Jul 2008
    Yes, the chip is a PIC16f819 so, as stated, any programmer will work. PicKit2, ICD2, *NEW* ICD3, lol There are plenty of schematics online for very simple PIC programmers with basically one transistor that will work and cost under $5 to build.
    Be careful though, this is an old version of the firmware. Last modified April 4, 2005 I don't see a version number but the newest is v1.4 and looks like it contains multiple fixes and new features which you'll lose if you recompile this old version. v1.4 applies to models after 6/8/08 it looks like, but I can't find a newer source
    Also, the code is atrocious, comments barely help. Intuitive enough to modify the delay times though I guess.. I work for Microchip so I'm a stickler about these things,
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Apparently the newer versions of M2 have some code changes which fixes certain timing issues (or so Ive read). So its probably best to stick with the newer code.
    Jun 2008
    Seattle, WA
    I have no problem modifying code to my liking, but not if it's old outdated code, that might be missing some critical bug fix that will keep me from having a dead battery. Oh well, I guess I'll just live with it.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Bump, any progress on this? I dont know anything about PIC programming, but can you extract the source code from the chip itself, or do you need to download it somewhere separately? The M series source code doesnt seem to be documented that well.
    Im eager to try this out if only I knew what to do. Doesn't really seem economical to buy a programmer just to shorten the delay by a few seconds. If there was interest, maybe someone can buy the chips in bulk, reprogram them and sell it off.
    These two programmers might work:
    http://cgi.ebay.ca/Enhance-JDM-PIC-p...d=p3286.c0.m14
    http://cgi.ebay.ca/Microchip-PIC-JDM...d=p3286.c0.m14
    Oct 2008
    UK
    Any news ... I'd be interested in a new chip for my M2 to get rid of that 5 second ON delay.
  1. M2 Atx .. qmm wires?
    By GreenBeauty in forum Power Supplies
    Last Post: 04-17-2008, 11:03 PM
  2. m2 ATX 160 Watt - voltage irregular?
    By MiniRX7 in forum Power Supplies
    Last Post: 11-16-2007, 11:32 AM
  3. M2 ATX power supply wiring question... 3 terminals
    By Snortonnorton in forum Power Supplies
    Last Post: 07-25-2007, 08:25 PM
  4. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 05:36 PM
  5. m2 atx with hardoff=never
    By Nerd2 in forum Power Supplies
    Last Post: 04-10-2007, 09:53 AM
