Yep, just link it in somewhere along the acc line going to J3 on the M2-ATX . Connect the cathode (striped end of the diode) to the J3 line, and connect the anode (non striped end of the diode) to ground. I put mine near the 15A fuse I installed on the wire just after the splice into the acc line coming out of the ignition key harness. But equally, you could do it right at the connector into the M2-ATX if you wanted.
LinkBack URL
About LinkBacks
