Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
Thread: novice M2-ATX question
  1. #11
    Variable Bitrate csfile's Avatar
    Feb 2009
    Quote Originally Posted by Enraiha View Post
    Just to be safe, make sure the computer does and still will power up i connected it to the ac power supply and plugged the computer into the wall and powers up fine no issues.
    Just wanted to make sure I understand what you said here. Was this a separate power supply? Or did you connect your M2 to a AC source?
    Did you check if j8 is outputting anything? You can try out j9 in case something's wrong with j8.
  2. #12
    Mar 2009
    thanks for the follow up. i used the computer's ps, not the M2.just to make sure i didn't do any damage to the computer itself,
    I did check the output of the J8 and didn't get any output as well as plugged into the j9 and check it with the multimeter too and didn't get any power out of any of the pins. Should there be a constant flow into any of the pins ?
  3. #13
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    but what is the amperage? that's what causes components to heat up.
  4. #14
    Feb 2009
    I honesty don't remember if it should be a constant signal or a pulse. Maybe you can hook some LED up to it.
    oh..one last thing, I unplugged the atx 20 pin from the PS, checked the voltage out of the pin out on the mobo and the only voltage i got from any of the pins is the +5 volt Standby.
    Are you getting 12V anywhere?
  5. #15
    Mar 2006
    Colorado, but Canadian!
    J8 connects to ground when switched. You might be able to read it if you connect one pin of your multimeter to ground the other to one of the J8 pins. It should read open line (O.L.) or not connected or something until the pulse is sent. If you have a crappy/cheap meter though it may not be fast enough to register it.
    And it is a pulse, not constant.
    1.9in x 2.9in -- 47mm x 73mm
  6. #16
    Mar 2009
    Quote Originally Posted by Injector View Post
    are you talking about the rocker switch its 20amps
    Quote Originally Posted by 2k1Toaster View Post
    KK, i've gotta work the next 4 days..12 hrs shifts so had to put my car back together..there's 3 of us with 4 cars..and i was hogging up the whole garage with my accord..lol
    Quote Originally Posted by csfile View Post
    not that i can see..though..i said above in the mobo i meant in the psu. when i unplugged the atx cable to the M2..and checked the pin out on the 20 pin m2, i got a +5v in the +5 standby.
    I've got +12v going into the M2 and i check at the fuse as well and there's 12v there..other than that..no no where else.
  7. #17
    Mar 2009
    i think i may set up a bench test for the m2-atx. since i'll be working the next few days..i can't NOT work on it..its definitely boggling my mind why it won't work. Will keep you folks posted when i get it tested
  8. #18
    Mar 2009
    YEAH!!! i benched test my m2 and after rewiring everything..it works!!!!!!!!!! at least now i know my m2 is not bad, tested the time delay jumpers and all is well yippeee!! now just gotta install it in my car...
    Thanks everyone for your help thus far! wish me luck getting it in the car
  9. #19
    Feb 2009
    nice...good luck
  10. #20
    Mar 2009
    Okay so i've moved everything from my desk to my car...and...didn't work .
    I'm so frustrated i have no idea what to do. so......
    I've decided to take pics of what i got and see if you guys can tell me what i'm doing wrong..keep in mind i'm not technically minded and this is my first attempt and I AM A GIRL, please don't rip me to hard..I'd like not to blow up my car considering its only 4 months old and i'm only a few thousand shy of paying it off
  1. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 05:36 PM
  2. Wtb :: M2 Atx Dc/dc Psu !!!
    By CoupeE46 in forum Classified Archive
    Last Post: 01-28-2007, 04:06 PM
  3. M2 ATX - EN15000 - USB - Problems!
    By BulleDK in forum Power Supplies
    Last Post: 12-28-2006, 04:29 PM
  4. M2 ATX Manual
    By lanman1 in forum Power Supplies
    Last Post: 08-16-2006, 02:28 PM
  5. Powerin the LCD with the M2 atx
    By luckyno in forum LCD/Display
    Last Post: 01-20-2006, 02:14 PM
