this setup worked on the bench. so I would guess there's something wrong with the way you're supplying 12V (either constant or switched) to the power supply. I bet you have, but I'm not sure if you've checked the simple stuff (no blown fuses, battery voltage, ignition signal voltage, kill switch not off, etc). I'm also not sure what pic3 is. Does that go to your M2?
LinkBack URL
About LinkBacks
