Results 1 to 3 of 3
Thread: M2-ATX Blows fuse on switched 12V line
    Jun 2009
    Tried searching, but I haven't found anyone with a similar problem.
    Recently I have had a strange problem with my M2-ATX. The fuse in the switched 12V line will blow at random times. The switched line on the M2 should pull very little power, correct? Do you think I have a bad PS?
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    sounds like a wire is shorting out. could even be the mobo shorting out. best idea is to check all the wiring with a multimeter and give the wiring a shake at the same time.
    Variable Bitrate csfile's Avatar
    Feb 2009
    It should pull very little power. It could be possible that the switched line is shorting somewhere. You could check that the wire insulation is not damaged or pinched.
  1. Xbox w/ M2 ATX and PSU convertor
    By MiniRX7 in forum Power Supplies
    Last Post: 11-25-2007, 07:45 AM
  2. m2 ATX 160 Watt - voltage irregular?
    Last Post: 11-16-2007, 11:32 AM
  3. M2 ATX installation trouble with ignition signal?
    By Snortonnorton in forum Power Supplies
    Last Post: 07-26-2007, 01:55 PM
  4. m2 atx with hardoff=never
    By Nerd2 in forum Power Supplies
    Last Post: 04-10-2007, 09:53 AM
  5. Wtb :: M2 Atx Dc/dc Psu !!!
    By CoupeE46 in forum Classified Archive
    Last Post: 01-28-2007, 04:06 PM
