Results 1 to 7 of 7
Thread: M2-ATX works as regular PSU (P0) only
    Oct 2009
    I just bought a brand-new M2-ATX. However, it works only in P0 mode i.e. when M2-ATX works as a regular PSU. I searched the forum but haven't found a solution for this issue.
    The setup is correct:
    J1 is connected to +
    J4 is connected to the ground wire
    J3 is connected to + through a switch immitating ACC function
    J8 is connected to the power switch jumper on the motherboard (Zotac 630i)
    J9 is connected to the power on button of the case
    When M2-ATX is in the P0 mode it works fine - the motherboard starts up. The power button turns the PC on and off
    When the PSU is in P1 or P2 mode and ACC is switched on - nothing happens. Neither the power on button works. I tried both positions of J8 plug - no impact on behavior.
    Does anybody had such issue? I would rather solve the problem by myself because getting a replacement is going to take a month (I live outside of the US)
    Elsewhere
    Try reversing the polarity of the lead from J8.
    How about the Wiki?
    Oct 2009
    As I said I tried both positions of J8 already. It's not the reason. If J8 were placed incorrectly the motheboard wouldn't start in P0 mode when Power On button is pressed on the case. So probably the reason is not J8. And I checked the voltage on J3 - it's 12v. So J3 is not the rootcause as well
    Apr 2009
    I am having this exact same problem. Anyone ever find a solution?
    May 2010
    did this get resolved? I have same prob.
    Oct 2009
    It was resolved by sending back to the shop and getting a replacement
    May 2010
    Thought so, thanks. put in RMA request 3 days ago and sent email with no reply.
  1. newbie needs help with m2 atx
    By luna123black in forum Newbie
    Last Post: 08-05-2009, 10:54 AM
  2. hooking up amp remote wire to m2 atx
    By mm87 in forum Car Audio
    Last Post: 07-16-2009, 03:11 PM
  3. M2 Atx .. qmm wires?
    By GreenBeauty in forum Power Supplies
    Last Post: 04-17-2008, 11:03 PM
  4. Replies: 0
    Last Post: 12-08-2005, 11:41 PM
  5. Replies: 11
    Last Post: 01-13-2003, 03:55 AM
Tags for this Thread
