Results 1 to 9 of 9
Thread: M2-ATX included power connector's wire too thin?
    Nov 2009
    Question M2-ATX included power connector's wire too thin?
    Hey guys
    Quick question that I haven't been able to find via search... I bought this stage 2 system from here: http://store.mp3car.com/Mp3Car_Custo..._p/ccc-122.htm
    The included P4 cable to supply power to the M2-ATX power supply has 18AWG 12v positive, accessory and ground wires. However, I will be supplying the power to the M2-ATX via a 10AWG wire directly from the battery. My question is, should I get a new P4 plug that I can fit a 10 AWG wire into for the 12v positive wire? I think 18AWG is too thin given the max amp draw of around 12amps? Or have you guys just connected the thicker gauge wire from the battery to the 18AWG P4 wiring? I would rather not create a hot spot!
    Many thanks
    Oct 2008
    UK
    The P4 cable doesn't supply power to the M2 ... it supplies power to the motherboard from the M2.
    Nov 2009
    Quote Originally Posted by NibbleIT View Post
    Sorry probably have my terminology wrong...The cable I'm talking about plugs into the back of the car pc case and is meant to be wired up to 12v battery, accessory feed and then a ground. I thought the plug was still a P4 style. In either case it powers the power supply, so the same question applies I guess thanks
    May 2006
    Calgary, Alberta
    I know the cable you're talking about, got the same one on my Ampie and it's not P4.
    The gauge of wire is directly related to the length of the wire. You could run a 20 foot 4 gauge wire and a 1 inch 18 gauge wire and they'd probably (just a guess for illustration purposes) run at the same resistance. So as long as the thinner wires aren't very long, you can likely just solder the 10 gauge right to them and be fine for that short distance.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    If you google on wire ratings you'll find the rating for 18AWG wire, and the maximum current draw for the M2 fits within the rating for this wire. I don't remember the numbers but I checked them when I first got my M2.
    I ran 12 gauge wire to a terminal block, and connected the 18AWG wire to the block as well. Works fine.
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
    Nov 2009
    Maheriano & Zogg,
    Thanks for your responses! When I was looking up the current ratings for the wire, I didn't think to take into account that the length of the 18AWG wire would be very short and hence might be OK. I saw that the "Maximum amps for power transmission" was only 2.3A on this table http://www.powerstream.com/Wire_Size.htm and I thought the M2-ATX draws up to about 15A?
    Thanks again!
    Nov 2009
    Actually, I should be looking at the "Maximum amps for chassis wiring" right? http://www.powerstream.com/Wire_Size.htm
    That's what was confusing me when I was looking at "Maximum amps for power transmission"
    Thanks Maheriano & Zogg for clearing things up guys.
    Apr 2009
    Toronto, Canada
    Thanks for that answer as well. I had the same concern with a mo-co-so case.
    May 2006
    Calgary, Alberta
    Quote Originally Posted by cheap1 View Post
    No problem. Electricity is a funny thing.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. M2 ATX power supply wiring question... 3 terminals
    By Snortonnorton in forum Power Supplies
    Last Post: 07-25-2007, 07:25 PM
  2. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 12:38 PM
  3. M2 ATX Power on problem
    By JWise1203 in forum Power Supplies
    Last Post: 07-26-2006, 11:24 AM
  4. Travla AC/DC power supply cable
    By Change in forum Power Supplies
    Last Post: 07-25-2006, 10:04 PM
  5. Pseudo-FAQ: What Do I Need For A Carputer?
    By Maheriano in forum General MP3Car Discussion
    Last Post: 07-03-2006, 02:04 PM
