Page 13 of 15 FirstFirst ... 3456789101112131415 LastLast
Results 121 to 130 of 142
Thread: Re-engineered M2-atx firmware with fixes and added functionality
  1. #121
    Constant Bitrate BADMOPAR's Avatar
    Mar 2007
    Sokolov, Czech Republic
    My M2ATX sometimes turn of my computer and sometimes don't. Will your chip solve this problem?
    I don't wanna be a product of my environment.
    I want my environment to be product of me.
  2. #122
    Feb 2010
    Kentucky
    Quote Originally Posted by BADMOPAR View Post
    It depends on what is causing your computer to not turn off. What happens when your computer does not turn off? Does it start to shut down and not have time to finish or does it just sit there as if the ignition had never gone off?
    My firmware will make it easier to diagnose what is going on when the computer does not turn off because you can look at the LED to see when the power button press to the motherboard happens and it will flash an error code if the motherboard does not respond as expected.
  3. #123
    Mar 2007
    Exactly, my computer still runs as if the ignition had never turned off. When I purchase M2 - ATX, turning on/off has worked perfectly. It stops working after one year or so. I spend a lot of time to setting up M2 - ATX jumpers and Windows, but have no luck.
  4. #124
    Mar 2010
    Does anyone know if, when the m2 is set to HardOff=Never, the 12volt rail goes off after the OffDelay?
    I've got a fan hooked to the 12volt rail because my Intel d510MO doesn't seem to drive a fan. When the ignition is turned off the computer shuts down but the fan keeps running.
    Thanks,
    davidk
  5. #125
    Feb 2010
    Kentucky
    Quote Originally Posted by davekra View Post
    Thanks,
    davidk
    I can really only say what happens in my code...
    The button press to the mobo is sent when the offdelay is complete. Power remains on the 12V rail until the motherboard has indicated that shutdown is complete and then everything is turned off except for the 5V standby rail. Power is removed from that after the hard-off timer is complete (which does not happen if hard-off is set to NEVER).
    I may be able to help if you can send me a picture or diagram of how you have the fan wired and a little more description of what happens when you turn off the ignition. Are you using your custom chip yet? Send me an email or a pm and I will try to help.
  6. #126
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Is there a list of the LED error codes anywhere? I have my system on the bench and it's not turning on.
    I'm getting a couple of long blinks followed by a number of 3 rapid blinks.
    It's connected to a Motorola base station power supply that is putting out 15V, which is a bit high but should work fine. I've used it before.
    Thanks!
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  7. #127
    Dec 2008
    email sent to blu. im ready to buy!
  8. #128
    Feb 2010
    Kentucky
    Quote Originally Posted by Zogg View Post
    Thanks!
    The error code is actually the long blinks and the patterns were referenced in the sheet that I sent with your pic. Here they are for reference:
    Error Codes: If the PSU shuts down unexpectedly, watch the LED for an error code to determine the cause. The error code will flash for 15 seconds and then the PSU will resume normal operation.
    1 long blink: Battery voltage under threshold
    2 long blinks: 3.3V rail under threshold
    3 long blinks: Mobo button press timeout (no PS_ON# low)
    4 long blinks: Voltage rise timeout
    5 long blinks: Mobo button press timeout (no PS_ON# high)
    If you can determine which one you have, I will try to help you with it.
  9. #129
    Apr 2005
    Plano, TX
    Quote Originally Posted by bluTDI09 View Post
    Thanks for posting, I must have misplaced the sheet and to be honest don't even remember getting one LOL.
    I did get it to turn on finally, but it's acting a bit funny. I popped in the original pic and got the same behavior, although no LED code, so it's not your chip. I'll do some more testing with it tomorrow and let you know if I can narrow it down.
    Typing this it occurred to me that I may not have had the power switch wired up properly with the M2 on the bench. I'll check that.
  10. #130
    Apr 2005
    Plano, TX
    Yep, pilot error. I had lines connected to the M2 for a power switch but on the other end of my octopus cable it wasn't actually connected to anything. So I think the blinkies were No. 3 above, although occasionally it would be only one blink, pause, blink, pause, then back to the 3 blink cycle.
    Thanks for posting the list, though, that triggered the thought and made me realize my mistake.
  1. DigitalFX 4.0
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-27-2014, 05:48 PM
