Results 1 to 4 of 4
Thread: M2-ATX not sending on signal to MB
    May 2009
    I recently upgraded my motherboard and I went to turn it on but nothing happened. I connect all the wires right and I used a key to jump the power button jumpers on the mb and it all turned on just fine any ideas why?
    May 2009
    Anyone?
    Dec 2008
    if you connected all your wires right, then it must be a bad power supply. i am going to bet the wiring is not right though. i would try flipping the motherboard power switch header wire around, there is only one pin that the m2 grounds out.
    May 2009
    tried that. Sadly I thought it would be the power supply. Thanks for the input.
  1. Engine Noise with M2 ATX
    By lucky1 in forum Power Supplies
    Last Post: 08-26-2010, 09:04 PM
  2. m2 ATX 160 Watt - voltage irregular?
    By MiniRX7 in forum Power Supplies
    Last Post: 11-16-2007, 11:32 AM
  3. M2 Atx
    By Punky in forum Power Supplies
    Last Post: 11-10-2007, 12:43 AM
  4. LCD won't signal MB to power RCA out
    By tropez in forum LCD/Display
    Last Post: 10-23-2003, 04:13 PM
  5. FS: LCD Controllers - $90.00+shipping
    By infrared in forum Classified Archive
    Last Post: 07-20-2003, 09:30 AM
