Results 1 to 9 of 9
Thread: M2 atx J8 busted?
    Nov 2008
    M2 atx J8 busted?
    So i parked my car during the winter so i can redo a couple of things, bushings seals.
    I figured while i have my car off the road i will redo my install and just make it look cleaner so i had my carputer sitting on a shelf for 3 months i went to connect everything yesterday and for some reason my M2 is not sending a power on signal from J8 to the motherboard.
    I tried to connect a switch to J9 and the manual switch also wont turn it on.
    If i put a manual switch on the motherboard it powers up just fine.. Could J8 have just died while it was sitting??
    Elsewhere
    Have you tried reversing the polarity?
    How about the Wiki?
    Nov 2008
    Quote Originally Posted by DarquePervert View Post
    Yes i tried that.
    i also tried the J9 to see if that would send the signal to the mobo.. none work.
    i put a volt meter to them and they show no power
    Mar 2010
    Sevilla, Espaņa
    Good people! You see, I have the same problem as Project_330CI partner. But my M2 has not been idle, just dismounted the CarPC to replace the timber in which DM had it installed by a sheet to avoid a very annoying parasites in the audio. When reinstalling pair test, the motherboard is not lit. As I understand it may be that the electronic component that is just above the J8 a bit to the left is melted. See if someone was able to solve this problem because I'm almost 1 month with the disassembled CarPC: (
    Greetings to all, very good read little things here, we note that there are good people!
    I feel my English, I use a translator ...
    May 2009
    same here after 2 years of good service. anyone found a solution?
    Mar 2010
    Sevilla, Espaņa
    Quote Originally Posted by hadaak View Post
    Hello!
    Yes, I'm ... But that is not removed. It's working with a button to switch the M2
    May 2009
    can you give more detail on how you're using a button to power up the M2-ATX with a busted J8 pin, please ??
    Nov 2003
    Connecticut
    the M2ATX is a POS, im another with a busted J8. what happens is you reverse the polarity on that pin, u fry the circuitry that creates the "momentary pulse" needed to boot the motherboard. now, you'd never know that because they don't mention it anywhere, and the wire they supply to you will go on either way.
    when i contacted customer support, i got nothing.
    Newbie Spacelord's Avatar
    Oct 2006
    Same problem. Same Hardware.
    Car: Volvo XC60
    CarPc: intel D945CLF2, 7"-Touchscreen, RoadRunner, IGo8
    HiFi: Diabolo D19/AndrianAudio A165g,2xPolk DB10, Signat RAMbo pimped, BRAX X2000
  1. newbie needs help with m2 atx
    By luna123black in forum Newbie
    Last Post: 08-05-2009, 09:54 AM
  2. hooking up amp remote wire to m2 atx
    By mm87 in forum Car Audio
    Last Post: 07-16-2009, 02:11 PM
  3. M2 Atx .. qmm wires?
    By GreenBeauty in forum Power Supplies
    Last Post: 04-17-2008, 10:03 PM
  4. M2 ATX installation trouble with ignition signal?
    By Snortonnorton in forum Power Supplies
    Last Post: 07-26-2007, 12:55 PM
  5. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 04:36 PM
