Results 1 to 2 of 2
Thread: Did I break my M2?
    Newbie MX5_Carputer's Avatar
    Mar 2010
    Did I break my M2?
    I feel pretty dumb right now. I had the computer running on my bench using a 13.5v dc supply simulating the car battery feeding the m2-atx. I am really bad with anything wiring electrical wise and ended up trying to measure amps by connecting my multimeter across the positive and negative in parralell! There was a spark from the tip of my multimeter probe and the computer died instantly.
    The 13.5v bench power appears to still be working. The motherboard powers up when plugged directly into a pc supply. However nothing happens when plugged in via the m2. The 15A spade fuse has not blown either.
    What is likely to have happened?
    Mar 2010
    ...update
    I took everything out, pushed everything back home and hey presto she fired up, turns out when i was prodding around with my multimeter i dislodged the wire connecting the bench terminal to the m2 and began to break out into a mild panic!
  1. Need Alpine wired remote control pinout.
    By FordNoMore in forum Input Devices
    Last Post: 07-15-2015, 09:31 AM
  2. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  3. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 05:36 PM
  4. Replies: 6
    Last Post: 07-06-2006, 11:28 PM
