Results 1 to 2 of 2
Thread: Startup / shutdown issues
    Constant Bitrate chronoglass's Avatar
    Nov 2009
    ok, so i've got the m2-atx 140watt
    I'm using a 400 watt atx psu to power it.
    When i have the thing is ps0 (dumb psu mode) I get 12v across the molex 12v rail.. like i should. So i've got the +12 going to the + on the m2-atx. Then the ground right next to it going to the - on the m2-atx. Then the plug going from j8 to the mb power switch header. Everything starts fine when i apply power.
    I put the jumper in the "reccomended" position on the m2-atx (jumping b if I remember right). I then run the switched (center pole on the m2-atx between + and -) to a switch and from the switch I run to the +12v that im pulling power from.
    I power up and test and am getting 12v across the unswitched power.
    I flip the switch.. and nothing happens.
    I recheck the power.. now it's at 9.4v
    I check the switched line.. 9.4v
    I flipthe switch back to off and check the power line.. 12v
    So i put the Voltimeter inline (removing the + wiring.)
    As soon as I flip that switch I go to 9.4v
    So i decide.. maybe i need to plug into something that provides a bit more power. So i probe the atx supply for the +12 and the -5 (which turns out without any load is giving me 18v) and try that out..
    everything goes to 9.4v (except the 5's, 3's and ground of course.)
    now this WAS a gaming PSU from about 4 years ago. and it WAS used to power an athalon processor.. which from what I understand ran at/around 9.6v.. perhaps it's kicking into "running mode" after it gets a proper load?
    Just kinda throwing this out in hopes someone has seen it and can confirm it's the PSU (before I start looking at the computers around me like zed in borderlands.. mmm organs!)
    I'll do the bumbling, and i'll be the idiot.
    if you've got a "stupid" question, search for some of mine!
    ids
    ids is offline
    Oct 2009
    Didn't work for me in the house using an old PC PSU either.
    It needs more that 12v for it to pulse/sense. When you have it in your car it will work
  1. Some power issues, ignition and shutdown etc..
    By k0m3k in forum Power Supplies
    Last Post: 09-19-2007, 02:32 PM
  2. Survey: Startup times and methods
    By gnomad in forum General MP3Car Discussion
    Last Post: 01-02-2007, 11:55 AM
  3. Startup / Shutdown scripts?
    By distler in forum Road Runner
    Last Post: 10-04-2006, 05:55 PM
