Results 1 to 2 of 2
Thread: M2-ATX Startup Help Needed
    Low Bitrate atrixstars's Avatar
    Oct 2006
    hi, I have been reading the manual. But I am confuse between jumpers J3 vs (J8,J9).
    Can the M2-ATX start without the J3 pin getting power? I have relays setup to mometarily "push" J8 or J9, like your pushing the power button Or switch the J1 or J3 around and used either (J8,J9) to start the computer?
    Short Version: I don't want to use J3 pin but I want to start the psu with J8 or J9 with an external switch.
    Here is the manual for ref: linky
    My CarPc Blog (<This is outdated. I have updated to a fully running Carpc System)http://acurafuse.blogspot.com
    Jan 2006
    I haven't tried it, but it should work without J3 getting power, as long as J1 (+ve) and J4 (-ve) are connected properly.
  1. Engine Noise with M2 ATX
    By lucky1 in forum Power Supplies
    Last Post: 08-26-2010, 08:04 PM
  2. M2 atx reset carpc after using car devices
    By ravid in forum Power Supplies
    Last Post: 03-11-2009, 03:38 PM
  3. M2 Atx
    By Punky in forum Power Supplies
    Last Post: 11-09-2007, 11:43 PM
  4. Problem m2 atx and 3.5" hard drive
    By Mitski's Rider in forum Power Supplies
    Last Post: 10-05-2006, 11:52 AM
  5. guru's help needed! (atx)
    By embedded in forum Power Supplies
    Last Post: 05-11-2001, 07:33 AM
