Results 1 to 5 of 5
Thread: Connecting M-2 in car
    Oct 2007
    Hello,
    I am trying to install original xbox with m-2 power supply. I have two questions. First one is " do I need to connect m-2 directly to car battery?" I think I have three options:
    (1) I can use cigarette lgihter
    (2) I can use fuse tap from the fuse box
    (3) connect directly to car battery
    Which one do you recommend? My second question is if I choose either option (2) or (3), how do I find accessory wire? I have never done it so your help is highly appreciated.
    Jay
    Elsewhere
    #3, definitely.
    Don't forget to fuse your power line close to the battery!
    As far as an ACC line, you can check sources that have wiring diagrams. http://the12volt.com is one.
    There is usually an ACC line running to your radio harness or possibly cigarette lighters or a clock.
    Think about devices in your car that are only on when your ignition is on....
    How about the Wiki?
    Oct 2007
    Thanks for your answer. It makes a lot of sense. I truly appreciate your answers.
    Jan 2008
    for the acc line, i would also recommend testing the wire with a volt meter for proper functionality before trying to power any devices.
    when i wired my alarm system, i found 3 different wire color code charts, and there were inconsistencies between all 3.
    Oct 2007
    That is a great suggestion. Thanks.
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. Connecting monitor power(110v) to 12v car battery.
    By mack89 in forum Power Supplies
    Last Post: 02-28-2010, 09:20 PM
  3. install mac mini
    By ssteger in forum VaultWiki
    Last Post: 02-09-2010, 03:47 PM
  4. Replies: 13
    Last Post: 03-19-2009, 09:57 AM
  5. Connecting MP3 Player To Car
    By larebz in forum Car Audio
    Last Post: 05-12-2008, 11:08 PM
