Results 1 to 3 of 3
Thread: M2-ATX burned - help
    Apr 2009
    good day
    need your help, I have an M2-ATX supply that I blew.
    I switched from the positive and negative so burned a component of plaque present in the image.
    need to know what is the reference component in order to try to repair burned.
    be grateful.
    Thank you.
    It is most likely a diode which only allows current to flow one way. I think the PCB is also printscreened with "D1" which would support my theory.
    What value the diode is.......who knows! However it is most likely, something else will have burned, even if it's not see-able But you may be lucky ;-)
    Raw Wave
    Nov 2009
    From the pic & above it seems it is a reverse-biased to absorb negative transients - which it did and blew.
    Once that let go, the other reverse biased junctions would have fried. That means transistors in chips etc. IOW - as BigK wrote, a few else's may have burned.
    If only the (reverse biased) diode blew, the PSU will work without it.
    It would be any power diode - not critical; ideally the equivalent to IN4007 or 4007s etc.
    It isn't a reverse polarity protection diode (unless it coincidentally happened to be faulty - ie, a short).
    Either way, I'd say more has blown....
  1. newbie needs help with m2 atx
    By luna123black in forum Newbie
    Last Post: 08-05-2009, 10:54 AM
  2. hooking up amp remote wire to m2 atx
    By mm87 in forum Car Audio
    Last Post: 07-16-2009, 03:11 PM
  3. M2 Atx .. qmm wires?
    By GreenBeauty in forum Power Supplies
    Last Post: 04-17-2008, 11:03 PM
  4. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 05:36 PM
  5. Wtb :: M2 Atx Dc/dc Psu !!!
    By CoupeE46 in forum Classified Archive
    Last Post: 01-28-2007, 04:06 PM
