Results 1 to 2 of 2
Thread: my first carputer
    Nov 2010
    my first carputer
    Hi ..
    this my first carputer I need some help I have toyota corolla 2009
    I have M2-ATX ,629 lilliput screen and my old P4 computer I get motherboard , processor and ram from it..(can i use this motherboard and it save to PSU and my battery ??)
    first I install ordinary pioneer head unit to amplified and to get my sound through AUX
    then I put my case in trunk then connect the the two + and - wires to my battery ( where and how to connect the switch wire ?? ) because I connect The OEM switch wire to pioneer head unit..
    how to get power to my screen ?? I cant use the 12V AC/DC power adapter because i install it in dash
    can I make my auto switch to backup camera?? I don't have exposed wire
    Nov 2010
    Since I can some what decipher your engrish so I will try and answer your question.
    Install a power relay behind your screen using the IGN or ACC wire to turn it on. Run a 12V wire from your battery through the switched part of the relay. Use the output power of the relay to power your screen/head unit. Run that same power to the trunk to your "white" wire on the M2 PSU. Be sure and put a diode in reverse bias in line before the carputer so it will shutdown properly.
  1. My 2006 Scion xB (portable) Carputer setup! w/pics!
    By breaker021 in forum Show off your project
    Last Post: 01-05-2007, 09:34 AM
  2. Carputer confusion- n00b needing help
    By TonyMartin in forum Newbie
    Last Post: 03-10-2006, 12:11 PM
  3. Carputer confusion- n00b needing help
    By TonyMartin in forum General Hardware Discussion
    Last Post: 03-08-2006, 09:43 PM
  4. wikipedia: carputer definition
    By pRoFiT in forum Off Topic
    Last Post: 12-31-2005, 08:32 AM
  5. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 08:57 PM
