Results 1 to 3 of 3
Thread: Two possible issues with PSU
    Nov 2010
    The first issue is that when I turn off my car my PC will try to sleep and the wake right back up, then I have to turn the car back on which will cause it to do that again. I have to keep doing this until the pc decideds it wants to stay asleep.
    I have my remote turn on wire connected to my radio acc harness.
    Now I don't know if it is something in windows causing this or voltage from the radio acc line causing this
    running Win 7 ultimate w/ ASRock ion 330 board
    connected to bench psu everytime i would hit the power switch it would sleep and unslep like its supposed to do.
    I have a switch connected to the secondary power switch as well, would cause interference?
    My second issue is with the amp turnon switch. I have it hooked to a MITO-02 to supply my factory Fockford system the data signal to turn on the amp.
    it isn't turning on my amp at all, if I disconnect the mito and reconnect it the amp turns on instantly all fine and whatnot.
    Elsewhere
    I'm willing to bet there is a device that is set to pull the computer out of sleep mode.
    Logically, it would be a device that is sending data to the PC, which would initiate the wake up.
    I'd look at the GPS and perhaps keyboard/mouse, as they all send data to the PC.
    I can't help with the amp turn-on.
    How about the Wiki?
    Nov 2010
    Ok, I fixed the sleep problem, it WAS my peripherals waking it up instantly.
    Thanks DP
  1. So how do I get the PSU to turn on on ING?
    By Emo in forum Power Supplies
    Last Post: 03-28-2006, 04:49 PM
  2. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 02:16 PM
  3. Mastero 3.5 12v-12v PSU KIT fs
    By SteveC in forum Classified Archive
    Last Post: 09-28-2004, 12:04 PM
  4. Powering up normal ATX PSU
    By KimaX in forum Power Supplies
    Last Post: 09-28-2004, 01:08 AM
  5. Inverter and PSU success
    By magnetik in forum Power Supplies
    Last Post: 09-22-2001, 08:19 AM
