Results 1 to 2 of 2
Thread: M2-ATX timing
    riv is offline
    Dec 2009
    M2-ATX timing
    Just tried to measure shutdown and hard-off times - it never comes exactly, for example:
    1. If the "D" pins are connected then it should be like: 10 mins for shutdown and 1 hour for hardoff, when I got little more then 10 minutes (something like 10' 30") and hard off came in 1 hour and ~7 minutes.
    2. If the "C" pins are connected then it should be like 30 secs for shutdown but it gave me 31-33 secs.
    Is it normal?
    Feb 2010
    Yes, that is normal. The default firmware uses very approximate "ticks" for timing functions. If you need more precise timing, check out my custom firmware thread. I just put the firmware up for sale today
  1. newbie needs help with m2 atx
    By luna123black in forum Newbie
    Last Post: 08-05-2009, 09:54 AM
  2. hooking up amp remote wire to m2 atx
    By mm87 in forum Car Audio
    Last Post: 07-16-2009, 02:11 PM
  3. M2 Atx .. qmm wires?
    By GreenBeauty in forum Power Supplies
    Last Post: 04-17-2008, 10:03 PM
  4. M2 ATX power supply wiring question... 3 terminals
    By Snortonnorton in forum Power Supplies
    Last Post: 07-25-2007, 07:25 PM
  5. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 04:36 PM
