Results 1 to 10 of 17
Thread: ignition wire
    Feb 2011
    ignition wire
    Hi All,
    I have tried looking around and really canít find advice on this question.
    Basically i have an m2-atx that i am about to install. I understand the +ve wire goes to the car battery, grd wire to grounded part of the car. But what about the ignition wire... i have heard some people say +12v can that just be the battery too?
    I want my car pc to start up on the car starting up, and shut down when the car is engine off.
    Any help would be greatly appreciated!
    Neo
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ignition wire is as the description says a wire which has 12v when the ignition on and 0v when it isn't.
    SO you need to find something that only has power when the ignition is on.
    Normally your HU will have such a wire as well as a constant 12v and a -ve
    Jan 2008
    Quote Originally Posted by Enforcer View Post
    but i don't recommend tapping into the factory harness for constant power or ground!!!
    and make sure to fuse the power wire within 18" of the battery..
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    ^^^^ What he said. I run the ignition wire from my radio harness to my trunk, 4GA wire from the battery (fused very close to the battery) to a distribution block in the trunk, and 4GA wire from a good chassis ground to a distribution block. I have all of the power and grounds I need to power my computer, accessories, and amplifier.
    Raw Wave
    Nov 2009
    What ALL said above - especially the pics!
    But be careful with the HU switched power - often it is from ACC meaning it is OFF when cranking.
    IGN power remains on when cranking.
    The Ignition Coil+ may be a source for IGN +12V (albeit inconvenient) if you can't access the IGN Key Switch, or dash meters or tacho. EFI vehicles always have an IGN relay (ie, a reverse-polarity protected "main" relay that switches power to the ECU & injectors).
    Feb 2011
    HI all,
    Thanks for the replies, so i am pretty sure I understand what you are saying, I just need to find somewhere on my 350z where i can tap into the ignition, i suspect my best bet is going to be the bose stereo.
    The next question is i was planning to wire a 4pin molex to the end of my lilliput car cable, so i could then connect to the PC to have it on only when the pc was on. However my question is that half way along the lilliput cable is a small box that looks like it has some sort of transformer in it, do i remove this or leave it on? (if i leave it on the only pain is will it not get hot when hidden away under the carpet etc..
    Let me know your thoughts!
    Thanks again for all the advice!
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    That box is a choke to reduce electrical noise and keep the picture clean. It should stay.
    Feb 2011
    will it get hot and be a potential fire risk if hidden away?
    Jan 2008
    no, at the most, it will be warm to the touch.
    Mar 2010
    Quote Originally Posted by PhilG View Post
    Should that choke stay if the OP wires it to a molex and powered the screen from the PSU?
    That's what I did on my setup.
    I recall some thread or someone saying to remove it if going this route. What say yaw?
  1. BMW Ignition wire
    By maddop in forum Power Supplies
    Last Post: 12-04-2010, 12:54 AM
  2. best use for ignition wire?
    By mmayn412 in forum Power Supplies
    Last Post: 08-06-2009, 05:37 PM
  3. ignition wire for M2-ATX
    By Squadfer in forum Newbie
    Last Post: 02-07-2009, 08:53 AM
  4. M2-ATX J3 Ignition wire
    By Mibix in forum Power Supplies
    Last Post: 08-07-2008, 07:44 PM
  5. ignition wire
    By TeamRSX in forum Car Audio
    Last Post: 05-16-2008, 10:53 AM
