Results 1 to 5 of 5
Thread: M2-atx led?
    Feb 2011
    M2-atx led?
    Hi All,
    Put in PC and Screen today, all seems fine. However a few things seem odd:
    1.)My USB mouse still seems to be lit up after the car is off (and pc is off) any ideas?
    2.)The LED on the m2-atx is flashing even after 2 hours has gone by since hibernating the PC
    Any ideas?
    Jan 2008
    what are your jumper settings?
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by soundman98 View Post
    Pearl one, knit two, pearl one, knit two.
    sorry, couldn't resist
    Feb 2011
    off - on - off - off
    Low Bitrate chris_h's Avatar
    Apr 2010
    VT
    the LED *should* flash when hooked up to the PSU
    this signifies the grace period is active
    on the M2-ATX there's two settings "hard-off" and the power-down signal. the power down signal (the power button push) happens after the ignition goes off.
    during the grace period in between the power-down signal and the hard-off the LED will flash
    after the hard-off, the led should stop flashing
