Results 1 to 2 of 2
Thread: M2-ATX-HV 6-32V (140 Watt) difference with the M2-ATX 6-24V (160 Watts)
    Mar 2011
    Question M2-ATX-HV 6-32V (140 Watt) difference with the M2-ATX 6-24V (160 Watts)
    Hi ,
    I understand the difference theoretically but in practice have you any preference between the HV and the classic ; I've seen the M4 troubles so I 've changed my purchase choice to the M2 for a P5KPL-AM EPU micro ATX and probably an asus Xonar ou USB sound car with MM500 TFT .
    Thanks by advance
    Low Bitrate chris_h's Avatar
    Apr 2010
    VT
    from a reliability standpoint they're just the same.
    functionally (i'm going to state the obvious here) the "HV" has a higher voltage ability but lower overall wattage
    the pinouts on the unit itself are identical
    the form is identical
    the only real way to tell a difference is the "HV' model has a sticker that says "HV"
    ---------- Post added at 08:08 AM ---------- Previous post was at 08:06 AM ----------
    for most car PC installs of this nature, i'd recommend the M2-ATX (non-HV)
    the HV is really intended for higher voltage environments, or environments where the voltages fluctuate outside of the 6-24V range
    your typical 12v car setup should never need to take advantage of what the HV offers. i'd choose the higher wattage ceiling
  1. FS: 7"Lilliput 150 Watt Opus 90 Watt Opus XM Direct
    By Weatherboy in forum Classified Archive
    Last Post: 09-25-2006, 11:38 PM
  2. Replies: 6
    Last Post: 04-07-2006, 01:15 PM
  3. How many watts do I need?
    By maxcosity in forum General Hardware Discussion
    Last Post: 04-21-2003, 02:10 AM
