Results 1 to 4 of 4
Thread: Fan spins for few seconds, then dies but manual power switch works 100%??
    Jun 2011
    When I use my M2-ATX with its intended functionality (remote wire signaling mobo with "power" signal), my motherboard boots up, fans and HDD begin to work, but then the hdd dies within 3-4 seconds. However, I tried using the exact same setup, only switching the remote signal wire from the PSU to the Mobo for a "manual" power switch that one could find on a desktop pc, it works just fine!!
    only things connected are a 2.5" laptop hdd and a case fan... my computer is not particularly power intensive.
    what is the issue here? has anybody experienced this? it was working fine today, until I took everything out of my case to do a bit of housekeeping. keep in mind that the case has never actually been in my car - I am simply bench testing it using an atx psu. it's driving me off the wall - hope I don't have to RMA.
    Jan 2008
    what are your jumper settings?
    Jun 2011
    Quote Originally Posted by soundman98 View Post
    I leave it on "A" but I've tried other settings with no success in getting the psu to work.
    Constant Bitrate Rickk's Avatar
    Feb 2013
    Western Massachusetts
    I spent the last 24 hours messing with mine before I cant to the same conclusion.
    It would start, then a few seconds later it would shut down. I didn't time it, but it seemed like it would retry every 30 seconds or so... maybe a little more.
    I disconnected the shutdown wire from the M2 (that goes to the motherboard) and connected it to a pushbutton instead. Now it starts right up if I push the button and it keeps running after that.
    Did anyone ever find a solution?
    BTW, I did try reversing the polarity on the connector, just to see if it mattered... nope... it didn't matter. Also, it worked for a couple weeks or so before it started acting up.
    Rick
  1. HQCT works for a couple seconds and then hang..
    By nimikipod in forum Hardware Development
    Last Post: 05-16-2009, 06:00 AM
  2. Powering up latop with manual switch?
    By black06stang in forum Newbie
    Last Post: 09-26-2006, 10:37 PM
  3. Which Rotary Switch Spins Forever?
    By 2k1Toaster in forum Fabrication
    Last Post: 06-15-2006, 02:10 AM
  4. Switch from FM (Wintv) to XM no audio for 15 seconds
    By antimatter in forum RR Bug Tracker
    Last Post: 03-23-2006, 11:46 PM
  5. what is the easist way delay my switch 12v for 2 seconds???
    By bertybassett in forum Power Supplies
    Last Post: 04-25-2005, 12:01 PM
