Results 1 to 4 of 4
Thread: M2-ATX Not sending shutdown when ignition off
    Apr 2005
    Sorry if this is a repeat question because I feel it is, but a quick search and I couldnt find a solution. I will continue to search, but in the mean time here is my problem.
    I have J1 (RED) wired directly into my battery
    J3 (white) to my ignition (+ when key on)
    J4 (Black) Directly to ground
    J8 To Motherboard power
    J10 has a jumper on "A" which is P1
    I have just reinstalled my carpc into a new vehicle that I bought. Before this I always ran this setup in P0 (dummy) mode and had the positive (J1) on a relay/switch so I don't know if P1 /ever/ worked correctly.
    With everything off, I turn the key to "IGN/ON" and PC & screen boot up fine. when I turn the key to off position my monitor shuts off, but PC never even tries to sleep/hibernate/OR shut off. I have verified with a meter that it does infact lose power when I turn the key off so I'm thinking maybe the M2atx is bad? I have verified also that my power settings in the control panel are set to "Hibernate when power button is pressed"
    Also, if I manually hibernate/shutdown/sleep I find that the only way to boot the pc again is to pull the fuse thats going to J1 (remove power completely) then reinsert it.
    Anyone else having the issues I am?
    Apr 2005
    Switched a couple settings around in the bios and it works fine now.
    Jul 2010
    what settings did you change? cause i'm having a very similar problem .... I have a zotac mobo btw.
    Apr 2005
    Honestly I don't remember, But it's back to not shutting down again so i have unplugged it and haven't powered it on in a few weeks because it ****ed me off so much.
  1. M2-ATX not sending on signal to MB
    By packruler in forum M2-ATX
    Last Post: 02-19-2010, 11:25 AM
  2. Flash Help sending a $var to RR
    By JohnWPB in forum Road Runner
    Last Post: 09-28-2007, 04:09 AM
  3. Some power issues, ignition and shutdown etc..
    By k0m3k in forum Power Supplies
    Last Post: 09-19-2007, 02:32 PM
  4. Sending SMS
    By vicky_obee in forum PhoneControl
    Last Post: 07-29-2005, 06:52 AM
  5. sending WMP messages
    By pimpJ in forum Software & Software Development
    Last Post: 12-15-2004, 09:08 PM
