seems like a bad power supply... try powering it from another PSU and see if it is your problem...
Totaled car b/c someone pulled in front of me.
New build from old PSU but new PC.
Start car below 90 degrees -> Monitor hooked up to pc via molex turns on but PC won't boot.
Start car above 90 degress -> Works perfectly no issue ever.
I checked all my connections and I still have NO IDEA whats going on. How can the monitor get power yet the PC will NOT boot no matter what?!?!? I can't even manually boot it.
FYI: This issue happened once then over time got worse and worse.
Any idea what to look for first? Just an old PSU that I need to replace? ugh
CarPc
Project "Driver"
Planning [99.9%]
Parts Collected [98.5%]
Installation & Fabrication [98%]
Total Completion Level [96.9 %]
http://www.mp3car.com/vbulletin/work...ct-driver.html
Yup workers perfectly with a normal PSU. Its my M2-ATX but this is sooooo strange.
i own the m2 also... but from what i read on here... the m2 is a hit or miss product... sometimes you get a good one...sometimes you get a bad one..
CarPc
Project "Driver"
Planning [99.9%]
Any other alternative psu besides the m2 with the same price point?
