Results 1 to 4 of 4
Thread: query on M2-ATX
    Oct 2011
    query on M2-ATX
    I have already connected 4pin 12v plug from PSU to the motherboard, unless I connect this it won't power on. I want to connect my LCD monitor powersupply to this 4pin 12v plug from PSU. Is it possible to connect both, will the 4pin 12v plug be able to power the monitor as well as the motherboard..
    Elsewhere
    Draw 12v from a HDD power connector instead.
    How about the Wiki?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Personally I don't agree with running the monitor from the PC's PSU.
    Yes, it's great for a regulated 12v source. And I certainly recommend running your monitor of a regulated 12v source as opposed to directly from the battery.
    However if you have any delay on the PC shutdown, so that you can leave the car a return within say 10 mins (depends on what you set it to) and have the PC still on rather than it have to boot up each and everytime you pop into the petrol station, a shop, friends house etc, the monitor will still be on and shining bright attracting the unwanted attention of thieving scum.
    Then again, if you don't plan on a delayed shutdown no worries. (Oh, unless you have no shielding on the monitor, in which case it will reduce the range at which your remote keyfob will work for that minute or so the PC is on whilst it is shutting down cleanly)
    May 2010
    Moncton, New Brunswick, Canada
    If you don't want to shut down your computer when you have to turn your car off, you can install a UPS system. It will allow you to leave your computer on or in standby mode depending on system power requirements, drawing power from the auxilary battery when the voltage from the car's battery drops below 13.1 ±0.2 volts.
    See the following links for the UPS controller and aluminum battery holder, (you have to buy battery that fits the holder, or make you own from 1/16 inch aluminum).
    http://www.powerstream.com/DC-UPS-1212.htm
    http://www.odysseybatteries.com/acce.../hd680_545.htm
    As for the monitor being on attracting theives, you can create a button that activates a black screensaver,(or better yet an animation of a very Sophisticated car alarm system) or you can buy a false radio face to cover it up.
  1. BU-353 Query
    By Ban_One in forum BU-353 Globalsat
    Last Post: 06-26-2008, 10:52 PM
  2. UPS Power Query
    By UKGooey in forum Power Supplies
    Last Post: 12-06-2006, 12:54 PM
  3. Query on hibernate
    By alexstein in forum General Hardware Discussion
    Last Post: 04-17-2006, 05:56 PM
  4. Playlist query
    By GolfChick22 in forum Road Runner
    Last Post: 03-19-2006, 01:08 AM
  5. Hibernation query
    By wizz in forum Map Monkey
    Last Post: 04-23-2005, 12:39 PM
