Results 1 to 2 of 2
Thread: M2 Cold Weather Issues
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls, Ontario
    Okay. I realize that it may not be a problem with the M2 itself. But I thought I would start here.
    My system will not start up if the temperature is cold. We're talking 0c and below (approx.). Once the interior and PC warm up enough, there is a perfect boot. This is consistently repeatable.
    The power LED on one of my USB hubs flickers continuously during the time that ignition signal is applied (or 5 seconds after), no LED power-on on the other 2, and no power LED on the display (but it's on the 12V line, not 5V) until there is a proper power-up. Then all the LEDs come to life indicating that the PSU is firing up properly.
    It was mentioned to me that it "might" be condensation forming in the case (MB and PS in same box) and after it dries up the system fires up. While I can believe condensation can do this, even the fans are not spinning up during this time so I don't know how long it would take for condensation to dry up enough with little-to-no air flow.
    I'm wondering if the M2 is the issue, or if the MB might be giving the M2 startup issues. Or could one of the peripherals be causing it.
    I currently do not have much in the way of tools/supplies (heat guns, freeze sprays) to properly troubleshoot to the level of bad solder joints or flaky capacitors.
    Any help, ideas, or suggestions would be appreciated.
    John
    03 Cadillac CTS
    ZOTAC G43ITX-A-E 2.5ghz Core i3 2GB 160GB SSD
    Win7 Ultimate - OpenMobile - Directed HD - Wifi
    OMMaps + MS GPS Puck - WiFi via LTE Android phone
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
    Feb 2009
    I found that one of the 3 powered USB hubs I used was preventing the system from boot while cold. On a nice crisp -12c morning I started up the car and started pulling USB off the back of the computer. As soon as I pulled the one hub it fired right up. I shut everything down, plugged everything in except that suspect hub, and again it fires up. I left everything for another 2 hours so that it was cold, and again it would fire right up.
    I have managed to bypass this hub for now. Looks like a new one in my future.
    Cheers.
    03 Cadillac CTS
  1. Cold weather issues
    By Champak in forum Software & Software Development
    Last Post: 11-14-2013, 05:09 PM
  2. LCD vs cold weather
    By Nomader in forum LCD/Display
    Last Post: 11-06-2006, 03:33 PM
  3. Cold weather issues
    By Weatherboy in forum General Hardware Discussion
    Last Post: 11-12-2005, 12:33 AM
  4. Carputer and cold weather... very cold!
    By Topper in forum General MP3Car Discussion
    Last Post: 07-14-2005, 08:41 PM
  5. Anyone else having any issues with Cold weather?
    By bry21317 in forum General Hardware Discussion
    Last Post: 01-25-2005, 10:42 PM
