I will check my install I am no newb
Well then atleast be nice to Rudolph the rednose.
On a side note, anyone wanna beta test my new GPS speedometer altimeter when they get there M2 working?
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
2005 Ford Mustang GT <- - - UPDATED PICTURES
2003 KAWASAKI Z1000 - CUSTOM MODZ
MBK (AIM = IllMBKllI)
ahlan sama
from the wire color on the cable, it looks straight through. they are the same on both sides. The only difference are the molex extensions for the HD power and so on. I think it some kind of instability. And you people how can't get it to work have faulty ones.
Final Touches
Car: 2002 Mitsubishi Magna EI
CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
My replacement of M2-atx works great!
Now I can power my SP13000 perfect.
Big thanks to CarTFT.com for great support and help.
// Daniel Sweden
I used the tester I bought to test my M2 and all rails seem to be good except for -5v. Is that required to start the motherboard? Could that be my problem?
http://www.compusa.com/products/prod...139&pfp=SEARCH
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
So the led on -5V isn't lighting up?
Hmm possibly, I would say that it might be needed, but I'm not sure.
Let some other electrical geek tell you FOURSURE.
The -5 Volt Rails are typically only used for Legacy ISA slots, so theoretically you'd be okay without it, but I sort of doubt your system will boot if you are getting nothing on the -5 Volt Rails. On the other hand, looking at the M2-ATX Manual (pdf), -5 Volt Rails aren't listed in the power output table.
I take it that is not the problem then....Originally Posted by theminor
I guess I have two choices now...replace the M2 with an Opus or replcae the Motherboard....![]()
Im gettin pretty fed up with the M-2 and with minibox.
Now minibox is telling me they wont work on it because I didnt buy it from them. What is the reseller supposed to do for me, send me back one with the same damn problem?
Minibox-> never again.
I got my second M2 in yesterday and it doesn't work either. Same problem as last one, no 5v power. Very frustrating.
I'm not really mad at them, but so far its delayed me 3 weeks. Luckily this is my own private install. Now if it were for a client, then these delays would be much worse.
There's not many options out there. I'm going to try the Opus 150 next and finally the DSATX if needed. I don't need 220w and it costs a lot more, but there's not much choice is there?
