Page 12 of 26 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 252
Thread: M2 ATX Problem
  1. #111
    FLAC sama's Avatar
    Feb 2006
    London, UK
    if ur battery goes flat, then it's good enough?
    no seriously, I would say get a new one if it's faulty. simple as that in my book
  2. #112
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    Quote Originally Posted by ramy_zohair
    Mine has them closer to the MB.
    That 's really strange (didn't work the other way round)
    I honestly can't see it making a difference what way you install that cable, only diff i can see is maybe less foltage drop (if any) on the molex connectors, cause they aren't being carried across the wires from the ps to mobo.
  3. #113
    FLAC sama's Avatar
    Feb 2006
    London, UK
    this issue of swapping the molex around really is buggin me. I'm not disputing it, just annoyed by it! how can 1.5 + 2 = 3 not be the same as 2 + 1.5 ?
    My first guess was that it's dirty wires, but someone said that wasn't true. So my next guess is that it's some kind of resetting of the M2 or discharging of it's capacitors etc. is that plausible?
  4. #114
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by bash1979
    When you guys had problems with the 'original' M2-ATX, did the mobo EVER power up at all? Or were you having intermittent power issues?
    My M2 seems to be acting up intermittently. Some days it powers up fine, other days I get the classic "mobo doesn't post, but fan starts spinning".
    You think this is enough to justify an RMA?
    Mine was that way with the M1-ATX and again with M2-ATX as well.
    For the longest time I belived there was something wrong with the M1 and M2. I now firmly belive that there is nothing wrong with the M2 (or the M1 I used to have) and there is a mobo problem in terms of a grounding short. I even bought a new ATX PSU and hooked it up and the carputer acted the same excat way which is post some times, and not others.
    I was researching this and on another forum someone suggested two things that actually helped solve a similar problem for a member. I am going to try them both tonight when I get home:
    1- Swap case fan connectors. According to that post, if CPU fan and case fan connectors are not connected to their correct pins, the motherboard will fail to detect the CPU fan running properly and will fail to post sometimes.
    2- If above does not fix it, then remove everything, the mobo, the psu, the HDD, and everything else from the metal computer case, place them on antistatic bag (or dry cardboard) and run them. If it now works then there is some sort of a ground short that is causing this. Inspect the ground wires and insolate the posts where motherboard screws into.
    I will let you know what mine does tonight.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  5. #115
    FLAC sama's Avatar
    Feb 2006
    London, UK
    I will try to wear a fireman's hat tonight, see if that does anything
  6. #116
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by sama
  7. #117
    Jul 2005
    Quote Originally Posted by Zebelkhan
    Cool info....I'll definitely stay tuned to this thread...good luck tonight!
    The hard part for me is testing this issue. Because it happens intermittently, it's hard to know when something you've changed actually made a difference. For instance, at first I though my mobo wasn't powering up because of my USB hub drawing too much at bootup, so I unplugged the hub. Next bootup, everything was fine, and it seemed to work fine for a day or two....then the issue came back again.
    It's funny...I'd rather have the thing NOT work at all than have it work sometimes. Just easier to troubleshoot!
  8. #118
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    dont put the board or anything else with power on an antistatic bag. The reason its antistatic and has a silver sheen to it is because it is metal coated which will short everything out. Cardboard it good tho, rubber mat is better.
  9. #119
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by v8 scimitar
    That makes sense. Thanks for saving my butt!
  10. #120
    Dec 2004
    Bay Area, CA
    I know excatly what you mean. That has been my problem all along too, which now I find out made me unfairly blame some who may not have deserved it.
    In my case, when it does not boot, I can get it to post if I hit the restart button several times (5 or six times) in a matter of two seconds. Can you do the same?
  1. Xenarc Problem or Polarity Problem?
    By mbkowns in forum LCD/Display
    Last Post: 01-06-2007, 09:57 PM
  2. Combining two ATX cables
    By LockNTross in forum Power Supplies
    Last Post: 09-22-2006, 08:51 PM
  3. PW-120-M Problem
    By Shmeker in forum Power Supplies
    Last Post: 07-11-2004, 11:06 AM
  4. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
  5. Interesting problem trying to extend ATX switch
    By InFix in forum General Hardware Discussion
    Last Post: 12-21-2002, 03:52 PM
