Page 17 of 26 FirstFirst ... 7891011121314151617181920212223242526 LastLast
Results 161 to 170 of 252
Thread: M2 ATX Problem
  1. #161
    Jul 2005
    UPdate on my M2-ATX + SP13000 problem:
    Andrei from iTuner sent out a modified M2, and it seems to be working flawlessly. I have tried booting up twice, and it is operating as expected. I have not let it run for a longer duration, but will be testing it over the next few days.
    Just wanted to say that it is looking promising, and thanks again Andrei for your support thus far
    1997 Mustang GTS "Jenna"
    VIA SP13000, 7" Xenarc TSV, 200GB, 'modified' M2-ATX, 1GB DDR400/3200, BU-353. RoadRunner + LSXVoid
  2. #162
    Apr 2006
    Planet Earth
    Do you know what the nature of the modifications to the M2 are to make it work with the SP13000? Can existing units be modified?
    I am having the same problem.
  3. #163
    Jul 2005
    Get in touch w/ support from where you purchased from.
    Andrei from iTuner (manufacturer) was was great to work with and veyr helpful!!
  4. #164
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    read post 11 of this thread
  5. #165
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by Idaten
    My m2-atx issue isn't with the start-up, it's seems to fail when sending the shutdown signal. I read in another post that it may be due to a too short of signal being sent (3ms vs 20ms). I have a pretty standard setup: SP13000 & Windows XP. The only thing different is that I wired up a momentary switch to the J9 jumper (optional external on/off).
    After shutting my car off, I waited for about 10 minutes and it never tried to shutdown. I have it set to a 2 hour 'Hard off.' For the meantime, I have to shut it down manually every time I leave my car. What are my options and/or any suggestions on a fix?
    Check to make sure your BIOS is not set for a 4 second shutdown.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  6. #166
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    i have the same problem
    Final Touches
    Car: 2002 Mitsubishi Magna EI
    CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
    Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
  7. #167
    Sharjah, Emirates
    Just to let you guys know. my M2/SP combo is working fine in the car. just installed it 2 days ago, and it is flawless. i am powering it manually (through the power button) now as i am having a problem with the ign singnal. I've got a couple of questions though and would appreciate some help.
    Do i have to put a jumper on the ABCD pins for it to shutdown with the ign. I had it startup through ign but it doesn't shutdown even when the key is removed (same problem metioned above with Idaten - Idaten will you please get back and tell us what happened with you?).
    Another thing is that the m2 remote amp pin is not powering my rockford amp. i measured the voltage across the pin, and it was 12V, at the amps remote terminal, it is 6V what could be the problem that is causing that voltage drop?? I tried to use a relay, but it seems that the remote pin output doesn't have enough juice to energize the coil. I really hoped that pin could produce more current. (i gives around 20mA - using my multimeter)
    Thanks for the help any keep that usefull thread alive.
    Final Touches
  8. #168
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    i'm using the m2 with the sp13000 whith zero problems,all worked from the first time,i'm using factory default settings,(jumpers).and i have 2 amp's wich are turn on by the m2 remote output.
  9. #169
    Sharjah, Emirates
    Quote Originally Posted by EL CAMINO
    what do you mean by factory default settings?? do you mean no jumpers at all, and it shuts down with the ign???
    I can live with the remote amp problem, by using the ign signal from the car (my amps have a soft turn on delay anyway)
    But my problem with shutdowns is critical
    Final Touches
  10. #170
    Oct 2005
    Hou. TX
    Quote Originally Posted by ramy_zohair
    First, it sounds like you don't have the instructions for the EDIT (not amp, I meant M2). Go to MP3car store and download the PDF file on it. Page 2 shows all the jumper settings.
    The reason it doesn't matter if your amps have soft turn on or not is because the amp will be fully on while the PC is still booting and if you use analog outs the soundcard will sometimes make loud noises.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  1. Xenarc Problem or Polarity Problem?
    By mbkowns in forum LCD/Display
    Last Post: 01-06-2007, 09:57 PM
  2. Combining two ATX cables
    By LockNTross in forum Power Supplies
    Last Post: 09-22-2006, 08:51 PM
  3. PW-120-M Problem
    By Shmeker in forum Power Supplies
    Last Post: 07-11-2004, 11:06 AM
  4. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
  5. Interesting problem trying to extend ATX switch
    By InFix in forum General Hardware Discussion
    Last Post: 12-21-2002, 03:52 PM
