Page 4 of 26 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 252
Thread: M2 ATX Problem
  1. #31
    Variable Bitrate nadir_s's Avatar
    Oct 2002
    San Jose, CA
    the battery won't drain if the system is running that long??
    [ 5-spd 1996 M A X i M A SE ]
  2. #32
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Anyone use a tester yet?
    How to test your power supply when things don't boot.
    I got my M2-ATX from a local dealer rrbuggz and it works fine.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  3. #33
    Oct 2005
    Hou. TX
    I just got my M2 and am using it on a 1K AMD downclocked to 800 and with lowered voltage. I also unplugged the HDD and monitor to lessen the load.
    My M2 won't power it up either. It just seems to supply a small jolt of electricity though the mobo connector. I see the CPU and Northbridge fan rotate a small amount about every 5 seconds. Even when the mobo connector is unplugged and power is going to the M2 I see the LED I added (J5) blink on and off every 2 seconds or so.
    Anyone have any ideas?
  4. #34
    Jan 2002
    Long Island, NY
    The tester seemed to detect a small jolt of electricity? Or the tester that was installed into your hand at birth?
    Test test test!
  5. #35
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    Thumbs down bummer
    I got my modified M2 today so hats off to Andrei for a quick responce to this. Unfortunately its exactly the same, My SP1300 still wont go into post and boot . I have emailed Andrei to see what he thinks and am waiting a reply.
    Mark
  6. #36
    Jan 2002
    Long Island, NY
    Mark, have you tried powering your system with a regular PS from a desktop ATX?
    Also have you tried a tester like I mentioned above?
    If not, then your M2-ATX may be fine, and your board and/or other components may be malfunctioning.
  7. #37
    Jan 2002
    Long Island, NY
    Fixed the link above.
  8. #38
    Jan 2005
    Scotland
    yes I have tested it with a normal power supply and it boots fine, infact I have tested it with several and it worked on them all. I doubt the tester you are on about would show anything as all the voltages are there and correct. Its a timing issue aparentlly. And no it isnt my 12v source either as I am using a proper bench power supply capable of delivering 40A from 3v to 18v
  9. #39
    Jan 2002
    Long Island, NY
    Timing issue?
    Well if you hooked up a tester it would show if all the rails are getting power and stay on like a system. But if the tester goes off right away, then hmmm somethings wrong.
    And the tester don't rely on no atx power switch. I dono how your testing it. But instead of testing the motherboard and the bench power supplies. Why don't you test the real problem, the M2-ATX.
  10. #40
    Jan 2002
    Long Island, NY
    I promise you, the M2-ATX won't bite you if you hook up a tester up to it.
  1. Xenarc Problem or Polarity Problem?
    By mbkowns in forum LCD/Display
    Last Post: 01-06-2007, 09:57 PM
  2. Combining two ATX cables
    By LockNTross in forum Power Supplies
    Last Post: 09-22-2006, 08:51 PM
  3. PW-120-M Problem
    By Shmeker in forum Power Supplies
    Last Post: 07-11-2004, 11:06 AM
  4. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
  5. Interesting problem trying to extend ATX switch
    By InFix in forum General Hardware Discussion
    Last Post: 12-21-2002, 03:52 PM
