Page 6 of 26 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 252
Thread: M2 ATX Problem
  1. #51
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Quote Originally Posted by JasonWW
    I think LESLIEx317537 needs to be banned.
    Whatever. SO I've been helping people here for 4 yeras and you think I should be banned now cause he's telling me to shutup?
    Cause I told him to use a 10 dollar tester and he insists to use his 1000 dollar fluke meters?
    This is funny. I was trying to help duh!
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  2. #52
    Jan 2002
    Long Island, NY
    Let me rephrase what I was trying to help you do.
    Test your M2-ATX with a cheap simple tester, if the LEDs don't light up, then you can tell your vendor and he will exchange it.
    It's simple, no need to do anything furthuer, it should work without adding resistors to change the ramp timing, leave that to them if they screwed it up.
    But you keep telling me that my tester won't work, well if it doesn't it doesn't but maybe it will. If it does work as I said in my FAQ, it will take the guesswork out of what is and is not working.
  3. #53
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    cos your a twat read the post I did get a new M2 yesterday hence why I posted again. The new power supply was supposed to be modified ( you would have known that if you had read the thread) a lot of people are waiting on these so I was reporting that it didnt work for me. I dont need you jamming a a cheap pile of junk down my throat that tells you nothing, I dont need you telling me its broke, I know it is and I dont need a 2 year old going mine works yours doesnt. End of Story godbye.
    Ok back on to what the thread is about. I have been in contact a lot with Andrei and testing a few things so hopefully we will get to the bottom of this. I have a few other things to try out tonight that might tell a story so here is hoping.
  4. #54
    Jan 2002
    Long Island, NY
    Have you tried purchasing from another vendor?
    Maybe all his batches are bad?
    You said he just fixed it? Or you acutally got a new one? Meaning new board, not fixed or refurbished.
    My local vendor sold alot here and he hasn't heard any complaints from his customers. That's where I got mine.
    Also, this doesn't apply for you, but I noticed alot of people are testing the M2-ATX with Desktop PC Power Supplies. When I charged my Lithium Polymer batteries with my Triton battery charger hooked up to a PC PS, I had to add two ceramic resistors to bring the voltage up higher than 12 volts, cause it needed some load to get to the correct voltage.
    Hahah you mad.
  5. #55
    Jan 2005
    Scotland
    I got a new one, the new one is from the manufacturers. The old one was never broken it just wont boot an SP13000 or rather it just wont boot some SP13000's. Thats why the manufacturer changed the design. Read post 11 on this thread, that is a post from the manufacturer. The modified/new design was supposed to boot all SP13000 but in my case it hasn't worked. Nobody else who has the same problem has posted yet so I assume they havent recived their new unit yet.
    Your also spot on with the ATX supply, they will only put out the proper voltages when they have a load on them. They dont regulate properly when there is no or very little load.
  6. #56
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    V8 scimitar,
    I am replacing my M1 with a M2 which has not arrived yet. I also bought the tester LESLIEx317537 is recommending. With my M1 I had a similar problem. Tester showed the M1 to be good yet it failed to post just as your M2 failes. What is more, it was an intermittent problem so sometimes it worked several boots in a row, sometimes it did not for a long time. I could always boot the board if I rapidly pressed the reset button several times in a 2 second period. So the issue was definitely a "timing" problem. What bothers me is why it was intermittent. It should either have worked, or have not worked....correct? Does yours boot at all?
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  7. #57
    Jan 2002
    Long Island, NY
    Zebelkhas, that's good info to know that the tester showed it working and it still doesn't boot.
    You also checked the ram? (Just making sure)
  8. #58
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    Is this problem similar to the OPUS and some Biostar motherboards? I had to send it in to have it fixed becuase I had a older psu. I guess try a relay until this is fixed maybe.
    FROM PSU - PW-SW=========> RELAY | | | | = Motherboard pins
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
  9. #59
    Jan 2005
    Scotland
    that tester will only show that there is power on the rails it wont show anything else. I guess if the timing is marginal then sometimes it might catch it ok and sometimes it wont. Guess the same is true of the SP 13000, they must vary slightly in production so some boards will boot and some wont. At least thats all I can think of the reason being anyway. Trouble is it makes it a sod to sort, minibox is sitting with an SP that boots but mine doesnt, Lesliex will boot but Linde's wont. Its just a head nip really. What gets me is that all the normal ATX supplies I have tried boot the board just fine, from expencive to cheap and nasty. So there must be something very different about the way the M2 turns on because there must be a standard that all the normal supplies work. I know the obvious with it being intelegent but even in dumb mode (no jumpers set) it still wont boot.
    No mine wont boot at all, the board seems to hang so you have to hold the power button in for around 5 secs before it will power off. This means the rapid switching on and off cant happen. I did try on off quickly with the 12 power supply but it wouldnt boot this way either but then I didnt expect it to as the M2 takes about 3 sec to actually supply power to the board when it has just been connected up.
    It might be the same as the opus, no idea as I dont know what problem it had. What relay are you on about?
  10. #60
    Aug 2005
    Im having a similar problem (doh!)) Im using a amd socket a board- none of the via one that seem to be so problematic.
    I bought mine about 2 weeks ago- would that be the revision or not?
  1. Xenarc Problem or Polarity Problem?
    By mbkowns in forum LCD/Display
    Last Post: 01-06-2007, 08:57 PM
  2. Combining two ATX cables
    By LockNTross in forum Power Supplies
    Last Post: 09-22-2006, 07:51 PM
  3. PW-120-M Problem
    By Shmeker in forum Power Supplies
    Last Post: 07-11-2004, 10:06 AM
  4. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 11:55 AM
  5. Interesting problem trying to extend ATX switch
    By InFix in forum General Hardware Discussion
    Last Post: 12-21-2002, 02:52 PM
