Page 7 of 26 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 252
Thread: M2 ATX Problem
  1. #61
    Oct 2005
    Hou. TX
    Quote Originally Posted by LESLIEx317537
    Whatever. SO I've been helping people here for 4 yeras and you think I should be banned now cause he's telling me to shutup?
    Cause I told him to use a 10 dollar tester and he insists to use his 1000 dollar fluke meters?
    This is funny. I was trying to help duh!
    Well there is helping in a useful and constructive manner and then there is helping in an arrogant, childish, sarcastic and rude manner. I'm sure people are glad you are willing to help, it's just the manner in which you speak to them. Even I couldn't believe how rude you sounded. I wouldn't have banned you, but the thought crossed my mind.
  2. #62
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    Quote Originally Posted by nealric
    Im having a similar problem (doh!)) Im using a amd socket a board- none of the via one that seem to be so problematic.
    I bought mine about 2 weeks ago- would that be the revision or not?
    No I dont think it would have been unless you bought it direct from minibox, even then I doubt it.
  3. #63
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Zebelkhas, that's good info to know that the tester showed it working and it still doesn't boot.
    You also checked the ram? (Just making sure)
    How do you test RAM? I don't have another one to put in there...
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  4. #64
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    there are memory testing programs available, but usually run in DOS so without a floppy drive (i can't see many CarPC's having these) you might be up the creek. I don't know of any good ones off the top of my head, but my co-worker does and I can ask him tomorrow as he is out sick.
  5. #65
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Quote Originally Posted by Zebelkhan
    I'm not sure how to test it, if you don't have another PC to put it in or another chunk of ram.
    But try taking out the ram, and see what happens when you try to boot it, many mobo's will beep when no ram is installed.
    I actually just took my old CarPC out and it has two chunks of 256MB of PC133. One was Crucial, and the other Kingston. After bringing it into my house, and trying to install Windows 2003 server on it, it kept erroring, so I took the Kingston chip out and it worked. But I didn't test the Kingston Memory yet. It actaully could have been seated loose. But I did cheack the Kingston RMA site and I got lifetime on it, so I'll get around to it and maybe RMA it.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  6. #66
    Jan 2005
    Scotland
    Thumbs up Works at last
    At last after 7 weeks of poking meters here there and every where, testing this that and the next thing I finally have my carpc up and running on 12VDC The solution was simple in the end. I went out and bought an Opus 150 pluged it in and instant boot up. No messing no drama it does what it says on the box.
    Damn shame really because on paper the M2ATX is a better power supply. It has better shutdown controles and better still it has hard off so I will need to do a bit of modifiction to the opus so it will do hard off. Oh the other thing with the Opus is that its completely over priced and umm a wee bit bigger than the M2 but that isn't so much a problem for me.
    Anybody else who gets the revised M2 board please still post and let us know how you got on whether its good or bad news.
    Mark
  7. #67
    Sep 2005
    I am having a similar problem... I am curious whether the people having problems are using boards which require a stable +12V, since all the VIA boards mostly do not need a stable +12V to boot. It could be that the SP13000 does use the 12V line. I am using a single board computer that has on-board voltage regulation so I just need the +12V not the 5V & 3.3V. I did look at the PIC code and it seems that the "turn on" pulse is being sent before the +12V line fully powers up, this may explain what is happening. Other people having similar problems please post so that we can find a fix which could be as simple as an alteration in the PIC code, it would be a shame to have to throw away a really good supply because of this...
  8. #68
    Jan 2005
    Scotland
    so far as I know the only thing the SP13000 uses 12v for is the cooling fan.
  9. #69
    Dec 2004
    Bay Area, CA
    I hope Andrei realizes that he is losing good customers and come up with a fix fast....
  10. #70
    Variable Bitrate 0okami's Avatar
    Feb 2006
    USA
    did i mentione I also went with an opus instead?
    opus 120 here. I'm up and going. (well not really, still testing and installing ut its working good.)
    gotta wait to my next day off.
    ~0okami.Digital
  1. Xenarc Problem or Polarity Problem?
    By mbkowns in forum LCD/Display
    Last Post: 01-06-2007, 08:57 PM
  2. Combining two ATX cables
    By LockNTross in forum Power Supplies
    Last Post: 09-22-2006, 07:51 PM
  3. PW-120-M Problem
    By Shmeker in forum Power Supplies
    Last Post: 07-11-2004, 10:06 AM
  4. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 11:55 AM
  5. Interesting problem trying to extend ATX switch
    By InFix in forum General Hardware Discussion
    Last Post: 12-21-2002, 02:52 PM
