Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: m4-atx quick question
    Jan 2009
    ive posted this question twice already. and its not showing up in the forums.
    im new to mp3car and i dont know if there is a waiting period before what you post is shown but wow its been hours and id really like to get this started and hopefully get some answers/help
    so anyways i have a m4-atx power supply.
    does it get wired directly to the battery? 12v and ground
    do i put an inline fuse on the 12v wire and ignition or just 12v? and what size fuse/value.
    can my 1986 trans am v8 stock car battery handle powering the pc? i dont want to instal a separate battery
    please help these r simple questions. im new to car pc's
    thanks
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    Quote Originally Posted by Bobby_80s View Post
    That's because your first few posts are moderated. It's a spam prevention method. Please don't take it personally.
    Jan 2009
    thanks
    ok thanks for the heads up.
    now does anyone have any quick answers to my questions about the m4-atx power supply?
    Jan 2009
    come on anyone?
    come on mp3car.com guys, guru's
    this should be easy answers. i jsut want to double check here before i might ruin something in my car.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    thanks
    Just put a fuse on the 12v wire. No need for the ignition. Use 6 gauge or less with 15 amp fuse and you will be fine. That will fuse you up to 12 volts X 15 amps = 180 watts. If you need larger, use 4 gauge wire and a 20 amp fuse for 240 watts.
    It's not a question of your battery, it is a question of your alternator. If you aren't running anything completely outrageous and you don't have a trillion watts of amp power in the car, you'll be fine. What is your audio setup?
    Want to:
    Jan 2009
    thank you
    its stock alternator
    i have a basic audio system i upgraded all four speakers but cheap replacements from walmart
    same with a cheap 50 dollar cd player to replace the cassette player.
    no amp or subwoofer dont want one
    im putting in a regular desktop computer in the car, the smaller car made ones i purchased were too slow and coudlnt be upgraded
    i need around 250-280 watts according to the indoors powersupply specs
    thats why i bought the m4 atx cuz it can handle up to 280 watts(300peak)
    so still think i'll be ok?
    and directly off the battery is safe correct?
    and how do i know if im sucking too much power and need a better alternator?
    Jan 2009
    any thoughts
    any thoughts?
    Constant Bitrate insaneramman's Avatar
    Mar 2008
    South Carolina
    Smile Parts Store...
    Call or go to a parts store and they'll tell you how many amps your alt. is rated for. MY rule is take no more than 20% of that # for ACC. Also know that MY M4 draws power even when off and will kill my battery after 4 or 5 days of not driving.
    Mine is wired direct to the pos term. and grd to frame. 25 amp fuse at the batt.
    If you're wondering about enough power turn on all your gadgets and see if you headlights are dim. That is the easiest way.
    Jan 2009
    kill switch
    yea ive heard the stupid thing stll draws power even when off.
    i'm going to put a kill switch to ground for teh computer
    and flip the switch once the computer and car are off
    i don't need to have a dead battery just cuz i dont drive that much for a few days
    and i'll ask the parts store thanks
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    During my exam period I didn't drive my car for 2 weeks and the car started fine. The M4 is supposed to draw around 0.5mA when in the "Hardoff" state. I.e. All the power rails are off. But putting in a decent inline switch cant hurt! Although I would probably use a relay on the power line to the M4 and a switch to control that relay.
    Fox Mulder
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
  1. M2 ATX power supply wiring question... 3 terminals
    By Snortonnorton in forum Power Supplies
    Last Post: 07-25-2007, 07:25 PM
  2. Quick Question (USB, IR LEDs)
    By Un_discovered in forum Off Topic
    Last Post: 04-10-2007, 02:15 PM
  3. quick newbie question...
    By stangg172006 in forum Newbie
    Last Post: 01-18-2007, 01:17 PM
  4. Quick powerstrip/PSOne LCD question
    By parksgm in forum LCD/Display
    Last Post: 11-11-2006, 12:35 AM
